Hass.io component failed to load
sorry is this in the wrong section, I am having issues with my configuration.yaml and Hassio component.
whenever I add the media player platform to my config file, I get the following message:
The following components and platforms could not be set up:
* hassio
Please check your config.
any idea what to check?
You’ll need to give a lot more info for anyone to be able to help you.
Add the section of code for your media player component. Make sure you look at the blue box at the top and correctly format the code when you post it.
Also look at your home-assistant.log to see if the error there will give you more details on how to fix it.
Hi thanks, for the reply
I have been troubleshooting this evening, and I figured out the issue was a custom media player component. (https://community.home-assistant.io/t/enigma2-receivers-integration/44448/13
once I take this out of the config.yaml file, there is no problem.
I am unsure what the issue is with the custom component as it was working fine before the last hassio update, so guessing something broke during the update.
