I can’t find it in settings - it would be good to have it as an option.
When I’m editing a configuration file using “Configurator”, it always creates a copy starting with dot (.).
And some other tools (like for example AppDeamon) is also reading these files, totally not necessary.
It shouldn’t be the configurator that’s doing this. Here you can see, that it’s writing directly to the specified filename. If it writes into a filename that starts with a ., then it would only do that if you have opened a file that already starts with the ..
Please delete the .-files and verify that saving files using the configurator really creates those files. While doing that, please keep an eye on the filepath that’s shown above the editor. If it already shows the .-filename there, then it actually rather has problems opening the file.
