Hi all, I just recently shifted on to hass.io using instructions as https://www.home-assistant.io/hassio/installation/#alternative-install-on-generic-linux-server for my Intel NUC.
The link there points to Github Repo here: https://github.com/home-assistant/hassio-build/tree/master/install and the documentation there points out how to change the data dir for hassio, which is what I used for my install.
Everything was going well, even over a few updates until I updated from 89b2 to 89.0. After the update, I lost all my config and the version running was 87.1.
After some digging it seems that hassio has reverted to loading from the default source of /usr/share/hassio. I want my source located at /opt/hassio.
I know I can symlink it but would rather understand how to change hassio config to run from the alternate location.
Can anyone offer guidance?
