Hass.io dies or looses network connection
I’m new to hass.io. I setup on a raspberry pi 2 via Ethernet. After about 24 hours it either dies or looses network connect, I can’t tell. How do I debug, is there a log, I should be checking?
After a power off/on it resumes so I can ssh in.
Thanks in advance.
I am having exactly the same issue. Lasts about 24hrs and then appears to crash. After a reboot, seems to work again for 24hrs.
Not clear what logs I can refer to to try and diagnose the issue.
In the meantime, I think I’ll refer back to a Rasbian install as it’s seems most stable and also able to support things like dev rules and command line sensors.
