After install finish I noticed that Hass.ie is not displaying on the left panel. So I can not install anything. So I started google it this problem and I’ve found some information on the web. Some of I’ve found bring me here, But even then I did not fix my problem,
So firtst, in my configuration.yaml I did not have hassio: but discovery was there. So I added hassio: to config file, but then when I restart HA I’ve seen this:
[homeassistant.components.hassio] Missing HASSIO environment variable.
[homeassistant.setup] Setup failed for hassio: Component failed to initialize.
Also I was trying to comment out discovery and leave just hassio: but no luck this time as well
I’m sure I have only one HA instance running at the time. As I said , there is a bunch of threads about this, but none of those helped me.
I installed Hass.io by downloading the image file (image) and put it on a SD card with Etcher. After complete put the SD card in the PI, wait and the installation will go on till you see the HASS screen with Hass.io panel
I know, but thats not Hass.io. If you want to install stuff, you have to do it via ssh. With Hass.io you can install addons easy, but they both work. Do you see the Hass screen, entity’s, etc.? Than it works.
Ok, understand, I can do this in shell. Just one more question, this link what you sent me is just for configuration, but not exacly how to install mosquitto
Could you please confirm those steps are correct to install mosquitto
sudo apt update
sudo apt install -y mosquitto mosquitto-clients
Warning
There is an issue with the Mosquitto package included in Ubuntu 14.04 LTS. Specify protocol: 3.1 in your MQTT configuration to work around this issue. If you get this error AttributeError: module 'ssl' has no attribute 'PROTOCOL_TLS' then you need to set tls_version: '1.2' .
If you are running a Mosquitto instance on the same server as Home Assistant then you must ensure that the Mosquitto service starts before Home Assistant. For a Linux instance running Systemd (Raspberry Pi, Debian, Ubuntu and others) then you should edit the file /etc/systemd/system/[email protected] as root (e.g., sudo nano /etc/systemd/system/[email protected] ) and add the Mosquitto service: [Unit] Description=Home Assistant After=network.target mosquitto.service
If you are running a Mosquitto instance on a different server with proper SSL encryption using a service like Let’s Encrypt you may have to set the certificate to the operating systems own .crt certificates file. In the instance of Ubuntu this would be certificate: /etc/ssl/certs/ca-certificates.crt
Help me understand, I followed the instructions for installing a Hassio image onto a RPI3 and end up with an unbootable device, I connected an HDMI monitor to observe the boot process.
So I try the Hassbian image, this works and the device boots, but the default config complains about the default config not being able to setup.
Yes, I don’t understand the difference between Hassio and HomeAssistant, I thought hassio was a sub component of HomeAssistant.
Hassio consists of 2 docker containers. HassOS is a stripped down docker host that can run hassio on a pi (image) or a VM on a server. Hassio can run on normal docker, on a generic Linux install.
You don’t need hassio menu to use Home Assistant. Add-ons are merely other applications running in other docker containers alongside hassio.
Add-ons add to the functionality of the system as a whole, but you can install the same applications in any generic Linux install or in docker. Add-ons are not required.
HassOS is a minimal linux install which has Docker on it, with HassIO preinstalled. It runs headless, which is to say that that computer running it has no GUI (if you attach your RasPi to a monitor, it won’t give you an interface to use.
HassIO is a way of installing Home-Assistant inside docker. It includes a supervisor container and a container running Home Assistant. It allows you to install AddOns which are separate docker containers. The supervisor container of HassIO takes care of managing the other containers used for home assistant.
You can also add your own containers to Docker without HassIO caring about them.
You can run HassIO on a linux install that has a GUI, or one that is headless; in either case you can still use this computer to do other things, with docker running in the background.
Home-Assistant is the specific python program. This is what’s actually running at the core of every HA install.
Hassbian is a SD card disk image which is a Raspbian installation with home Assistant in Virtual Environment, pre-installed.
So, to summarize, the most popular install on a RasPi is HassOS, which is:
HassOS->Docker->HassIO->Home-Assistant+AddOns
On other devices (such as desktops, laptops, servers, NUCs), HassIO is the popular choice, which is:
LinuxOS(usually)->Docker->HassIO->Home-Assistant+AddOns
If you’re using Hassbian, that’s:
RaspianOS->PyVENV->Home-Assistant
I understand, I gave up normal Linux install (Raspbian+Home Assistant), and l also couldn’t see Hass.io.
I found out the hard way that Hass.io is not part of the Home Assistant, but it’s like a core thing in Home Assistant. If you want Mqtt Broker, you install it by Add-On. If you want Zigbee2Mqtt, you install Add-On. If you don’t have Hass.io you can do nothing. Because there’s also no explanation how to do it without Hass.io.
So, although Home Assistant looks cool, it really sucks on documentation. If I wasn’t married and have no kids, I could have plenty of time to figure things out or even help creating add-ons or write better documentation. But I’m a busy man with little time to have fun with home automation and the lack of good documentation is a bit stressful. And yes, I’m thankful to the volunteers for this nice project, but yeah, just my frustration.
It took me a very long time to figure this out but it seems Hassio tab no longer exists and you simply have to add the repository. I was trying to add the full repo link which never worked.
The correct repo to add is
Go to the Supervisor tab, then click Add-on store, click the hamburger (vertical ellipses thing) and click on the top right of the page and select repositories.
Add the above url and you will get access to all the community add-ons.
