Tom7320
(Thorsten)
November 12, 2019, 5:29pm
1
Hi
I have a huge problem. Suddenly my HassOS does not start anymore. Unfortunately I can not even login as root:
Is there any way I can resuscitate my installation? At least I need all my config files…
PS: It seems that HassOS supervisor does not start at all.
THX a lot!
shanem
(Shane)
November 12, 2019, 5:38pm
2
If it is the case and it is an SD card or something, I used some software on windows to get the config files, but it is on my other pc and i dont know what it is called. I think if you use your drive on Linux it can already read it or something. For now try this https://www.howtogeek.com/112888/3-ways-to-access-your-linux-partitions-from-windows/
Tom7320
(Thorsten)
November 12, 2019, 5:41pm
3
It’s a VM running within Proxmox. Is there really no other way to fix this?
francisp
(Francis)
November 12, 2019, 6:33pm
4
Resize your disk in proxmox
First hit on google :
Ok, i lied, there is no easy way to resize kvm but it's pretty fast if you know what you are doing. Finding Proxmox VE resources isn't very easy since not many people are actually writing this to share their knowledge across. I figured that i should...
Tom7320
(Thorsten)
November 12, 2019, 6:37pm
5
That does not help since I have to resize the file system (resize2fs in the guest). To do that I have to log in which I can’t…
For anyone else having this issue, here’s how I solved it. (Running HassOs as a Virtual Machine on VMWare ESXi).
Extend the disk in VMWare (or whatever Hypervisor you are running)
Download a live CD containing Gparted. (Gparted has a live CD you can use)
Boot up your HassOs-VM with the Live CD. Launch Gparted and extend the Hassio Data-partition.
Restart the VM and dismount the Live CD, so that the VM boots up from the default disk.
You should now be able to login.
