Hass.io, DuckDNS and FIOS
Has anyone had any luck successfully configuring DuckDNS and Let’s Encrypt using a FIOS Quantum router? I’ve tried multiple port forwarding settings on my FIOS router but have not successfully gotten DuckDNS and Let’s Encrypt to work.
Thanks!
Spiked
What model?
I have Fios-G1100 and configure port forwarding with no problem.
Same as @Vlad’s experience here. Before moving everything to Ubiquiti gear and ditching their “quantum gateway” I had no problems with port forwarding and Duck DNS.
Thanks for your input. Could you please let me know if this looks correct for the port forwarding:
xxx.xxx.xxx.xxx:8123 Destination Port: 443
TCP Any -> 443
I’ve tried multiple options so I’m not sure what is correct anymore…
Thanks for your help!
I redid the entries in the configuration.yaml file, rebooted, and now everything seems to be working correctly. Thanks for your help!
