At some point – I don’t really know when – bluetooth stopped working for me as a device tracker. Bluetooth devices aren’t detected anymore, and my logs are filled with the following, over and over and over:
2019-11-27 16:00:13 ERROR (MainThread) [homeassistant.components.bluetooth_tracker.device_tracker] Error looking up Bluetooth device
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 31, in discover_devices
lookup_class=lookup_class, device_id=device_id)
_bluetooth.error: (16, 'Resource busy')
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 140, in perform_bluetooth_update
devices = await hass.async_add_executor_job(discover_devices, device_id)
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 62, in discover_devices
device_id=device_id,
File "/usr/local/lib/python3.7/site-packages/bluetooth/bluez.py", line 34, in discover_devices
raise BluetoothError ("error communicating with local "
bluetooth.btcommon.BluetoothError: error communicating with local bluetooth adapter
The only thing I’m using bluetooth for other than device tracking is monitoring a Flic button, using the flicd add-on, and that appears to be working as expected.
Any idea what’s going on here, and how I go about correcting it? I’m running hassio (HassOS 1.13) on a Raspberry Pi 3B+.
_bluetooth.error: (110, 'Operation timed out')
Hi everybody,
New to the system and exactly same issue on on a RPi 3B+ and HA 0.104.3 / HassOS 3.8 / Supervisor 195.
Could be possible that there were a hardware or driver mulfunction ?
Some have found that reducing the baud rate fixes the issue but I’ve yet to find out how to do this within Hassio. I’ve been trying to use the /usr/bin/btattach command but unable to locate my built in BT device in /dev/ - any advice here?
Trying to run btattach -B (BT MAC Address) -S 460800 -N but doesn’t work…
I continue to keep having this issue with BT tracking crashing with any version of HassOS 3.x on a RP3b. BT tracking is solid on HassOS 2.12. I have a wired network connection and wifi not configured.
To easily roll back to HassOS 2.12, run the following command from SSH.
hassio os update --version 2.12
Thanks for the tip. Had to give up on bluetooth tracking completely until I read this.
Also found that having bluetooth tracker in the config was preventing hassio updates for some reason.
Rolling back to 2.12 has tracking working again. Will have to wait for the next update to see if that is fixed too.
