Now for some reason I can access my Hassio using Duckdns but can not access it using http://hassio.local:8123
This is driving me crazy. I remember last time part of the initial setup made it go from http to https but I have not done that yet, and tried https just to be sure and that does not work, so why does http://hassio.local:8123 not work now?
I’m having similar issues. I’ve been using DuckDNS and hassio for a long time now, but after deciding to do a fresh install I haven’t managed to get it to work. I’ve done the re-install numerous times now, and tried every combination of settings and http configs recommended in other threads, but I just can’t get it to work.
I realise this post doesn’t help, just needed to get that off my chest
for the local access, you still need to use https , you will get the errors about not a secure address, but you can click through (at least on Safari) and access it.
Question then, what makes logon change from http to https?
I have been accessing it through http to begin with as https was not working.
Now if I go to https it asks me to login with legacy password which I thought had gone in new versions of HA and when I do logon with my logon details it says error, while if I try and connect through http it just blank screens and says cannot be found
When I tried this on my system, and pointed my browser to https:mylocalip:8123 I was prompted for my userid and password, just like I would from a new browser using the external address.
Do you still have a reference to the legacy password in your config?
I will give it another go when I get home. Last night https and http were not working but then neither was duckdns for a bit and thats working from the office and accessing Hassio via terminal was working last night so fingers crossed its something minor.
I have a new install so no mention of a legacy password as far as I can see, this is my entire config so far…
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
#I added base_url, ssl_cert and ssl_key for Duckdns
http:
base_url: MYURL.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
