drdran
(Dr.Dran)
July 27, 2017, 5:01pm
1
Hi!
I’m thinking about to use one usb hdd for root drive with my Pi instead to use the normal micro sd for storage.
I use in my custom home-assistant installation on raspinan that adafruit guide:
One of the more noticeable limitations of the Raspberry Pi is using an SD card for its main storage. This guide details hooking up an external drive, copying your root filesystem to it, and configuring the kernel to treat the external drive as root....
That is based on that
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=44177
What do you think to include that on the new hass.io image?
So if I want I can use my external usb drive ad root filesystem storage that was more efficient that the micro sd.
Best Regards
Franco
This would be nice to have.
drdran
(Dr.Dran)
August 19, 2017, 6:07pm
3
ok, after holidays return I’ll take a look how to get this on resin-os base
Have you made any progress on the external drive option??
Jasonlr06
(Jason Rice)
February 4, 2018, 11:03am
5
Has there been any progress to the use of an external hard drive for HASSIO?
I have hassio on my pi3, installed in a Geekworm case with a SDD. I can not get the pi to see the hard drive to be able to use it as a boot from. If I connect the hard drive to my other pi3 that has the all in on installer on it with raspbian I can use dmesg and see the hard drive. Can you help?
Jasonlr06
(Jason Rice)
May 26, 2018, 3:25pm
7
I’ve heard nothing new and don’t know how to bump.
