Hi.
Anytime my envisalink card is down, hass.io hangs indefinitely on reboot, but stays up if envisalink goes down when hassio is up. Anyone else having this issue ?
Thanks,
Andre
Hi.
Thanks,
Andre
Hi Andrep1,
Did you solve this problem with the new updates or does it continue?
Best
Francisco
Bonjour,
I’m sorry I didn’t follow up with this. Changed the IP on the envisalink and rebooted. It failed graciously with “Setup failed for envisalink: Component failed to initialize.” and loaded up the interface so I would say this is fixed.
André
That’s great…. I had a similar problema and what helped was to disable DHCP on the Envisalink device. Hope that helps if you had any future problem.
Best
Francisco
The ip is fixed by config, it’s just Hassio wouldn’t startup if the panel was unreachable
Thanks Andrep1, I was taking about the DHCP of the Wifi Bridge I’am using to get internet connection on the Envisalink.
Best
Francisco
