Hass.io in Docker - Need help to upgrade to a beta version
I’m working on a problem with ConBee native ZHA integration and was asked to upgrade to the lastest Beta but I never have done it and could use some help… any would be appreciated.
I’m running hassio on Ubuntu 18.04 in Docker with Portainer… this is what my Portainer looks like.
HA
1.Stop homeassistant container
2.Select homeassistant container to access “container details” screen
3.Select [duplicate/edit] button
4.In the image section change “homeassistant/intel-nuc-homeassistant” to “homeassistant/intel-nuc-homeassistant:0.91.0b3”
5.Select [deploy container] button
Use link below to determine latest version for your HA version. Those with “b” beta
https://hub.docker.com/r/homeassistant/intel-nuc-homeassistant/tags
It took a couple tries for some reason, I think a delay in grabbing the new image from what the error was, but it ended up working perfectly!! I was sure there was no rocket science behind it!! HUGE Thanks this will help troubleshoot ConBee ZHA Integration issues with the developers, I’m the “Test Lab” at the moment.
