Hass.io installation alternative way (manually)
i am running my Smathome apps on a Debian Linux System with Proxmox. I have now installed a Debian Virtual Machine and have installed manually the HassIO System (Docker). Everything works fine.
One Question. I have followd the Guide on the Homeassistant Website. HassIO will be installed in a DockerContainer, but the System itself run under user Root? Is that correct? Or should i install the HassIO Docker Container with an unprivilege User with Docker rights?
Any suggestions?
Thanks and regards
Danyo
