I’m trying to install home-assistant via hassio on my OrangePi Lite board running the armbian OS. Everything seems to be installed fine, but when I try to start hassio I got an error:
same erreor here, it seem that homeassistant/armhf-homeassistant:landingpage does not exist in docker hub, but homeassistant/armhf-homeassistant exist and > $ docker pull homeassistant/armhf-homeassistant
give us a container, but i wass unable to have it running, probably due to numerous tests i made and there is something broke somewhere.
Hi, any update on installing hass.io on an OrangePi? I have an OrangePi Plus2 which is great for having EMMC on board, but I can’t get hass.io installed. Same errors as above posters. I’m running Armbian Ubuntu Bionic and followed the instructuctions on alternative-install-on-generic-linux-server
root@orangepiplus:~# systemctl status hassio-supervisor.service
● hassio-supervisor.service - Hass.io supervisor
Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2018-11-15 13:39:50 CET; 1h 56min ago
Main PID: 1976 (hassio-supervis)
Tasks: 13 (limit: 4658)
CGroup: /system.slice/hassio-supervisor.service
├─1976 /bin/sh /usr/sbin/hassio-supervisor
└─2022 docker start --attach hassio_supervisor
Nov 15 15:32:23 orangepiplus hassio-supervisor[1976]: 18-11-15 14:32:23 WARNING (MainThread) [hassio.homeassistant] Fails install landingpage, retry after 60sec
Nov 15 15:33:23 orangepiplus hassio-supervisor[1976]: 18-11-15 14:33:23 INFO (SyncWorker_10) [hassio.docker.interface] Pull image homeassistant/armv71-homeassistant tag landingpage.
Nov 15 15:49:48 orangepiplus hassio-supervisor[1976]: 18-11-15 14:49:48 ERROR (SyncWorker_13) [hassio.docker.interface] Can't install homeassistant/armv71-homeassistant:landingpage -> 404 Client Error
Here’s the way I fixed it on my Raspberry Pi:
Since I was affected by this issue as well, I finally figured out how to work around it.
Here are the steps I performed:
The above steps ensure everything is stopped and all containers are deleted, but not the images.
Now edit the file /etc/hassio.json: Replace "homeassistant": "homeassistant/armv7l-homeassistant" by "homeassistant": "homeassistant/armhf-homeassistant".
And start HassIO again systemctl start hassio-supervisor.
Thanks for the suggestion. I tried your steps, but unfortunately same error as before on my OrangePi…
I think I will continue with the VirtualEnv method and skip the hassio solution.
