Hass.io installed on X86 Up board: plugin manager is not showing
Hi.
I’ve been installing hass.io via docker on an up board using this guide.
I can see it using HA UI the browser on :8123 but I see blank page in the Hass.io tab.
In log details I read this warning
Error fetching description at http://10.100.1.1:49152/description.xml
Anybody experienced such a problem?
Would most of the plugin be compatible with an x86 Atom architecture?
One thing to add is that the configuration option fails in restarting the server.
It’s a known problem with all architectures. Have a read of this: Hass.io window not loading
TLDR: workaround is to use Chrome web browser.
Thanks. Will check.
mm not really on my computer (Ubuntu 16.04 desktop). But will investigate on this
it works super on chrome!
thanks!
EDIT1: I had to fix some strange chrome behaviours I have on my computer
You install with no problem on Up Board devices ? What model you have ? And on what system you install it ? Because on RPI3 i install it on raspian strech lite.
