Hi All
I just updated my rasp. with the latest update Home Assistant
0.81.5 and I keep getting this:
The IP reported is my HAss.io IP
I can’t find anything in the log file?
Br
Casperse
Hi All
Br
Casperse
I’m getting the same thing, my log file says
2018-11-05 01:12:42 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.x.x
I’ve just deleted my database and restarting HA now, hopefully I can make a new username and password
Is cloud
enabled in your configuration.yaml
No - But I am running Https with real certificate and my base url is now https, could that cause it?
mine has bee doing this as well, i tried using a different browser and it seems to work. i have problems using safari on OSX
This is crazy, I have disabled ban settings but I am still getting the notification many times a day?
Also went back to https as base url… but no change?
Can anyone confirm its a bug in the latest version?
I think for me it was Node Reed updating to v 1.0
Delete the user part
"log_level": "info",
"credential_secret": "",
"http_node": {
"username": "",
"password": ""
"http_static": {
"username": "",
"password": ""
"port": 1880,
"ssl": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"require_ssl": true,
"system_packages": [],
"npm_packages": [],
"init_commands": []
"users": [
"username": "",
"password": "",
"permissions": "*"
Node Reed now uses the HA aut. and I think it was creating the “blocking” every time it called a flow from Node red.
Also I had to point to a new URL inside Node Reed
The solution to this is simple:
http://hassio/homeassistant
.I just updated to 1.0.1 and I get invalid login now. I am using the credentials that were previously set and match the settings. Any thoughts?
Nevermind. I just saw your part that says Node Red now used HA Auth and that worked.
