I’ve had hass.io running on my raspberry pi for about 2 weeks now. I am mainly running it for the security boards Konnected which I have two of.
everything runs runs fine and works, but every few days hass.io just stops reporting. the IP is still pingable, and I can get to the login prompt with an attached keyboard and monitor. only thing I see on the console is about the wlan0 not responding, which doens’t matter to me since I am hard wired.
however hassio isn’t responding.
is there a log in on the console I can get in an look at the syslog? I originaly thought it was power related but I am on my 3rd power supply and a brand new class 10 U3 microSD card.
hassio -> system -> systemlog only shows me the current info, not what was on there before it locked up.
9-02-19 19:48:16 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-02-19 19:48:18 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.87.1
19-02-19 19:49:18 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-02-19 19:49:18 INFO (MainThread) [hassio.addons] Startup application run 2 add-ons
19-02-19 19:49:18 ERROR (MainThread) [hassio.addons.addon] Add-on core_google_assistant have wrong options: Missing required option 'project_id'. Got {'client_secrets': 'google_assistant.json', 'project_id': None, 'model_id': None}
19-02-19 19:49:18 INFO (SyncWorker_17) [hassio.docker.interface] Clean homeassistant/armhf-addon-configurator Docker application
19-02-19 19:49:22 INFO (SyncWorker_17) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 2
19-02-19 19:49:27 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-02-19 19:49:27 INFO (MainThread) [hassio.core] Hass.io is up and running
19-02-19 19:54:27 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-02-19 20:04:10 INFO (MainThread) [hassio.hassos] Syncing configuration from USB with HassOS.
19-02-19 20:04:10 INFO (MainThread) [hassio.host.services] Restart local service hassos-config.service
19-02-19 20:04:10 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.RestartUnit on /org/freedesktop/systemd1
19-02-19 20:24:27 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
any suggestions on where to start? I was planning on using this to replace my security system so I would like it to be online and reliable.
Thanks,
Seth
