Hass.io keeps restarting randomly
Running on an Atom-based NUC, 4GB RAM, 240GB SSD, Docker.
It seems to restart at random, at least 2-4 times every day, and I can’t figure out why. I grabbed /var/log/syslog from the host, and I see problems, but I don’t know what the root cause is. Any ideas?
Mar 15 11:42:53 ron hassio-supervisor[1826]: #033[32m19-03-15 15:42:53 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 11:52:54 ron hassio-supervisor[1826]: #033[32m19-03-15 15:52:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 11:52:54 ron hassio-supervisor[1826]: #033[32m19-03-15 15:52:54 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token#033[0m
Mar 15 12:02:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:02:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:12:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:12:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:17:01 ron CRON[29097]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 15 12:22:23 ron systemd-timesyncd[503]: Network configuration changed, trying to establish connection.
Mar 15 12:22:23 ron systemd-timesyncd[503]: Synchronized to time server 91.189.91.157:123 (ntp.ubuntu.com).
Mar 15 12:22:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:22:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:22:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:22:54 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token#033[0m
Mar 15 12:32:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:32:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:42:54 ron hassio-supervisor[1826]: #033[32m19-03-15 16:42:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:52:55 ron hassio-supervisor[1826]: #033[32m19-03-15 16:52:55 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 12:52:55 ron hassio-supervisor[1826]: #033[32m19-03-15 16:52:55 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token#033[0m
Mar 15 13:02:55 ron hassio-supervisor[1826]: #033[32m19-03-15 17:02:55 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:07:13 ron kernel: [265530.202504] traps: python3[26605] general protection ip:7f3fb5e94428 sp:7fff35225748 error:0 in ld-musl-x86_64.so.1[7f3fb5e87000+45000]
Mar 15 13:12:55 ron hassio-supervisor[1826]: #033[32m19-03-15 17:12:55 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:13:33 ron kernel: [265910.299579] traps: python3[782] general protection ip:7f3fb5e94428 sp:7fff35225b28 error:0 in ld-musl-x86_64.so.1[7f3fb5e87000+45000]
Mar 15 13:16:13 ron kernel: [266070.480490] traps: python3[3817] general protection ip:7f3fb5e94428 sp:7fff35225748 error:0 in ld-musl-x86_64.so.1[7f3fb5e87000+45000]
Mar 15 13:17:01 ron CRON[4641]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar 15 13:20:53 ron kernel: [266350.645545] traps: python3[8819] general protection ip:7f3fb5e946be sp:7fff35225a60 error:0 in ld-musl-x86_64.so.1[7f3fb5e87000+45000]
Mar 15 13:22:24 ron systemd-timesyncd[503]: Network configuration changed, trying to establish connection.
Mar 15 13:22:24 ron systemd-timesyncd[503]: Synchronized to time server 91.189.91.157:123 (ntp.ubuntu.com).
Mar 15 13:22:56 ron hassio-supervisor[1826]: #033[32m19-03-15 17:22:56 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:22:56 ron hassio-supervisor[1826]: #033[32m19-03-15 17:22:56 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token#033[0m
Mar 15 13:24:04 ron kernel: [266542.053538] traps: python3[12070] general protection ip:7f3fb5e94428 sp:7fff35225b28 error:0 in ld-musl-x86_64.so.1[7f3fb5e87000+45000]
Mar 15 13:25:24 ron hassio-supervisor[1826]: #033[31m19-03-15 17:25:24 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: #033[0m
Mar 15 13:25:24 ron hassio-supervisor[1826]: #033[31m19-03-15 17:25:24 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant API!#033[0m
Mar 15 13:25:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:24 INFO (SyncWorker_2) [hassio.docker.interface] Stop homeassistant/qemux86-64-homeassistant Docker application#033[0m
Mar 15 13:25:31 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:31 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not str#033[0m
Mar 15 13:25:31 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:31 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API connection is closed#033[0m
Mar 15 13:25:36 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:36 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:25:36 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:36 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:25:54 ron dockerd[1071]: time="2019-03-15T13:25:54.230701856-04:00" level=info msg="Container 960ed5a7dbd63f31fb0c015e1278c6f03978ff35ddcc559f8f578eac7dc687d1 failed to exit within 30 seconds of signal 15 - using the force"
Mar 15 13:25:54 ron hassio-supervisor[1826]: #033[31m19-03-15 17:25:54 ERROR (MainThread) [aiohttp.server] Error handling request#033[0m
Mar 15 13:25:54 ron hassio-supervisor[1826]: Traceback (most recent call last):
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
Mar 15 13:25:54 ron hassio-supervisor[1826]:     resp = await task
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
Mar 15 13:25:54 ron hassio-supervisor[1826]:     resp = await handler(request)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
Mar 15 13:25:54 ron hassio-supervisor[1826]:     return await handler(request)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/hassio/api/security.py", line 99, in token_validation
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 200, in websocket
Mar 15 13:25:54 ron hassio-supervisor[1826]:     client = await self._websocket_client()
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 115, in _websocket_client
Mar 15 13:25:54 ron hassio-supervisor[1826]:     url, heartbeat=30, verify_ssl=False)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 721, in _ws_connect
Mar 15 13:25:54 ron hassio-supervisor[1826]:     proxy_headers=proxy_headers)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 497, in _request
Mar 15 13:25:54 ron hassio-supervisor[1826]:     await resp.start(conn)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 844, in start
Mar 15 13:25:54 ron hassio-supervisor[1826]:     message, payload = await self._protocol.read()  # type: ignore  # noqa
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 588, in read
Mar 15 13:25:54 ron hassio-supervisor[1826]:     await self._waiter
Mar 15 13:25:54 ron hassio-supervisor[1826]: aiohttp.client_exceptions.ClientOSError: [Errno 104] Connection reset by peer#033[0m
Mar 15 13:25:54 ron hassio-supervisor[1826]: #033[31m19-03-15 17:25:54 ERROR (MainThread) [aiohttp.server] Unhandled exception#033[0m
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 447, in start
Mar 15 13:25:54 ron hassio-supervisor[1826]:     await resp.prepare(request)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 353, in prepare
Mar 15 13:25:54 ron hassio-supervisor[1826]:     return await self._start(request)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 667, in _start
Mar 15 13:25:54 ron hassio-supervisor[1826]:     return await super()._start(request)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 410, in _start
Mar 15 13:25:54 ron hassio-supervisor[1826]:     await writer.write_headers(status_line, headers)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 112, in write_headers
Mar 15 13:25:54 ron hassio-supervisor[1826]:     self._write(buf)
Mar 15 13:25:54 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 67, in _write
Mar 15 13:25:54 ron hassio-supervisor[1826]:     raise ConnectionResetError('Cannot write to closing transport')
Mar 15 13:25:54 ron hassio-supervisor[1826]: ConnectionResetError: Cannot write to closing transport#033[0m
Mar 15 13:25:54 ron containerd[1025]: time="2019-03-15T13:25:54.838060933-04:00" level=info msg="shim reaped" id=960ed5a7dbd63f31fb0c015e1278c6f03978ff35ddcc559f8f578eac7dc687d1
Mar 15 13:25:54 ron dockerd[1071]: time="2019-03-15T13:25:54.848342783-04:00" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Mar 15 13:25:54 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:54 INFO (SyncWorker_2) [hassio.docker.interface] Clean homeassistant/qemux86-64-homeassistant Docker application#033[0m
Mar 15 13:25:55 ron dockerd[1071]: time="2019-03-15T13:25:55.351113097-04:00" level=info msg="/etc/resolv.conf does not exist"
Mar 15 13:25:55 ron containerd[1025]: time="2019-03-15T13:25:55.424652286-04:00" level=info msg="shim containerd-shim started" address="/containerd-shim/moby/f8377c8e5d9cc4b79ba795a6bb06dc88644f3cc8cd4d07ddb5519958b153bdc4/shim.sock" debug=false pid=13469
Mar 15 13:25:56 ron kernel: [266653.103567] udevd[7]: starting version 3.2.7
Mar 15 13:25:56 ron kernel: [266653.125734] udevd[8]: starting eudev-3.2.7
Mar 15 13:25:56 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:56 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.89.1#033[0m
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.2743] device changed (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0/net/ens34, iface: ens34)
Mar 15 13:25:56 ron ModemManager[805]: <info>  (net/ens34): released by modem /sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0
Mar 15 13:25:56 ron ModemManager[805]: <info>  (tty/ttyACM0): released by modem /sys/devices/pci0000:00/0000:00:1d.3/usb5/5-2
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.4974] device changed (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0/net/ens34, iface: ens34)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5707] device changed (path: /sys/devices/virtual/net/veth04398d7, iface: veth04398d7)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5805] device changed (path: /sys/devices/virtual/net/hassio, iface: hassio)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5810] device changed (path: /sys/devices/virtual/net/lo, iface: lo)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5831] device changed (path: /sys/devices/virtual/net/veth2b95d7a, iface: veth2b95d7a)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5916] device changed (path: /sys/devices/virtual/net/veth2ef1722, iface: veth2ef1722)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5921] device changed (path: /sys/devices/virtual/net/veth6abdac0, iface: veth6abdac0)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5925] device changed (path: /sys/devices/virtual/net/vethc10e5bd, iface: vethc10e5bd)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5969] device changed (path: /sys/devices/virtual/net/vethd97177b, iface: vethd97177b)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5974] device changed (path: /sys/devices/virtual/net/vethcd6c73e, iface: vethcd6c73e)
Mar 15 13:25:56 ron NetworkManager[798]: <info>  [1552670756.5978] device changed (path: /sys/devices/virtual/net/docker0, iface: docker0)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.1758] device changed (path: /sys/devices/virtual/net/docker0, iface: docker0)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2568] device changed (path: /sys/devices/virtual/net/hassio, iface: hassio)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2622] device changed (path: /sys/devices/virtual/net/veth6abdac0, iface: veth6abdac0)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2648] device changed (path: /sys/devices/virtual/net/lo, iface: lo)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2777] device changed (path: /sys/devices/virtual/net/veth04398d7, iface: veth04398d7)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2864] device changed (path: /sys/devices/virtual/net/vethcd6c73e, iface: vethcd6c73e)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.2938] device changed (path: /sys/devices/virtual/net/veth2b95d7a, iface: veth2b95d7a)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.3122] device changed (path: /sys/devices/virtual/net/veth2ef1722, iface: veth2ef1722)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.3139] device changed (path: /sys/devices/virtual/net/vethd97177b, iface: vethd97177b)
Mar 15 13:25:57 ron NetworkManager[798]: <info>  [1552670757.3179] device changed (path: /sys/devices/virtual/net/vethc10e5bd, iface: vethc10e5bd)
Mar 15 13:25:59 ron ModemManager[805]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.2/0000:02:00.0': not supported by any plugin
Mar 15 13:25:59 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:25:59 ron hassio-supervisor[1826]: #033[32m19-03-15 17:25:59 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:25:59 ron hassio-supervisor[1826]: #033[31m19-03-15 17:25:59 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].#033[0m
Mar 15 13:26:04 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:26:04 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:04 ron hassio-supervisor[1826]: #033[31m19-03-15 17:26:04 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].#033[0m
Mar 15 13:26:07 ron hassio-supervisor[1826]: #033[31m19-03-15 17:26:07 ERROR (MainThread) [asyncio] Task exception was never retrieved
Mar 15 13:26:07 ron hassio-supervisor[1826]: future: <Task finished coro=<WebSocketWriter.ping() done, defined at /usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py:628> exception=RuntimeError('unable to perform operation on <TCPTransport closed=True reading=False 0x55d250cbbf78>; the handler is closed')>#033[0m
Mar 15 13:26:07 ron hassio-supervisor[1826]: Traceback (most recent call last):
Mar 15 13:26:07 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 632, in ping
Mar 15 13:26:07 ron hassio-supervisor[1826]:     await self._send_frame(message, WSMsgType.PING)
Mar 15 13:26:07 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 614, in _send_frame
Mar 15 13:26:07 ron hassio-supervisor[1826]:     self.transport.write(header + message)
Mar 15 13:26:07 ron hassio-supervisor[1826]:   File "uvloop/handles/stream.pyx", line 671, in uvloop.loop.UVStream.write
Mar 15 13:26:07 ron hassio-supervisor[1826]:   File "uvloop/handles/handle.pyx", line 159, in uvloop.loop.UVHandle._ensure_alive
Mar 15 13:26:07 ron hassio-supervisor[1826]: RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x55d250cbbf78>; the handler is closed#033[0m
Mar 15 13:26:09 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:09 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:26:09 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:09 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:09 ron hassio-supervisor[1826]: #033[31m19-03-15 17:26:09 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].#033[0m
Mar 15 13:26:14 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:26:14 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:14 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:14 ron hassio-supervisor[1826]: #033[31m19-03-15 17:26:14 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].#033[0m
Mar 15 13:26:18 ron ModemManager[805]: <info>  Creating modem with plugin 'Generic' and '1' ports
Mar 15 13:26:18 ron ModemManager[805]: <warn>  Could not grab port (tty/ttyACM0): 'Cannot add port 'tty/ttyACM0', unhandled serial type'
Mar 15 13:26:18 ron ModemManager[805]: <warn>  Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:1d.3/usb5/5-2': Failed to find primary AT port
Mar 15 13:26:19 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:19 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:26:19 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:19 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:19 ron hassio-supervisor[1826]: #033[31m19-03-15 17:26:19 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].#033[0m
Mar 15 13:26:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:24 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:26:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:24 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:24 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running#033[0m
Mar 15 13:26:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/config access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:24 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:26:26 ron hassio-supervisor[1826]: #033[32m19-03-15 17:26:26 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance#033[0m
Mar 15 13:26:58 ron kernel: [266715.360670] python3[14480]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:27:28 ron kernel: [266745.740061] python3[14991]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:28:19 ron kernel: [266796.068132] python3[15829]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:29:19 ron kernel: [266856.520852] python3[16860]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:29:59 ron kernel: [266896.656749] python3[17526]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:30:19 ron kernel: [266916.885578] python3[17869]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:30:40 ron kernel: [266937.066558] traps: python3[18198] general protection ip:7f1a1b7b5428 sp:7ffc4a5ffa88 error:0 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:31:20 ron kernel: [266977.250960] python3[18874]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:31:30 ron kernel: [266987.450199] python3[19041]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:32:40 ron kernel: [267057.924349] python3[20256]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffc28 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:32:51 ron kernel: [267068.174238] python3[20424]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:32:51 ron kernel: [267068.953103] python3[20435]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffc28 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:33:01 ron kernel: [267078.117291] python3[20579]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:34:21 ron kernel: [267158.744456] python3[21947]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:35:22 ron kernel: [267219.143729] python3[22963]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:35:32 ron kernel: [267229.161999] python3[23130]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:36:02 ron kernel: [267259.182130] python3[23633]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:36:12 ron kernel: [267269.199896] python3[23789]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:36:25 ron hassio-supervisor[1826]: #033[32m19-03-15 17:36:25 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:36:32 ron kernel: [267289.190982] python3[24128]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:36:42 ron kernel: [267299.245587] python3[24286]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:39:52 ron kernel: [267489.376271] traps: python3[27561] general protection ip:7f1a1b7b5428 sp:7ffc4a5ffa88 error:0 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:45:34 ron kernel: [267831.615656] python3[1139]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:45:44 ron kernel: [267841.603017] python3[1301]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:46:04 ron kernel: [267861.982490] python3[1644]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:46:25 ron hassio-supervisor[1826]: #033[32m19-03-15 17:46:25 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:47:55 ron kernel: [267972.383236] python3[3751]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:50:05 ron kernel: [268102.772871] python3[6073]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:52:36 ron kernel: [268253.023911] python3[8677]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:53:56 ron kernel: [268333.485424] python3[10072]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffc28 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:53:57 ron kernel: [268334.277557] python3[10075]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:54:16 ron kernel: [268353.621023] python3[10402]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffe98 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:54:53 ron hassio-supervisor[1826]: #033[32m19-03-15 17:54:53 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token#033[0m
Mar 15 13:55:47 ron kernel: [268444.064738] python3[11934]: segfault at 563500000090 ip 00007f1a1b7b540d sp 00007ffc4a5ffea8 error 6 in ld-musl-x86_64.so.1[7f1a1b7a8000+45000]
Mar 15 13:56:26 ron hassio-supervisor[1826]: #033[32m19-03-15 17:56:26 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3#033[0m
Mar 15 13:58:07 ron hassio-supervisor[1826]: #033[32m19-03-15 17:58:07 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not str#033[0m
Mar 15 13:58:07 ron hassio-supervisor[1826]: #033[32m19-03-15 17:58:07 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API connection is closed#033[0m
Mar 15 13:58:12 ron hassio-supervisor[1826]: #033[32m19-03-15 17:58:12 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:58:12 ron hassio-supervisor[1826]: #033[32m19-03-15 17:58:12 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:59:04 ron hassio-supervisor[1826]: #033[32m19-03-15 17:59:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:59:04 ron hassio-supervisor[1826]: #033[32m19-03-15 17:59:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 13:59:55 ron hassio-supervisor[1826]: #033[32m19-03-15 17:59:55 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 13:59:55 ron hassio-supervisor[1826]: #033[32m19-03-15 17:59:55 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:00:24 ron hassio-supervisor[1826]: #033[31m19-03-15 18:00:24 ERROR (MainThread) [hassio.homeassistant] Error on call http://172.30.32.1:8123/api/: #033[0m
Mar 15 14:00:24 ron hassio-supervisor[1826]: #033[33m19-03-15 18:00:24 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home Assistant#033[0m
Mar 15 14:00:46 ron hassio-supervisor[1826]: #033[32m19-03-15 18:00:46 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 14:00:46 ron hassio-supervisor[1826]: #033[32m19-03-15 18:00:46 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:01:38 ron hassio-supervisor[1826]: #033[32m19-03-15 18:01:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 14:01:38 ron hassio-supervisor[1826]: #033[32m19-03-15 18:01:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:02:30 ron hassio-supervisor[1826]: #033[32m19-03-15 18:02:30 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 14:02:30 ron hassio-supervisor[1826]: #033[32m19-03-15 18:02:30 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:03:22 ron hassio-supervisor[1826]: #033[32m19-03-15 18:03:22 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 14:03:22 ron hassio-supervisor[1826]: #033[32m19-03-15 18:03:22 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:04:14 ron hassio-supervisor[1826]: #033[32m19-03-15 18:04:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize#033[0m
Mar 15 14:04:14 ron hassio-supervisor[1826]: #033[32m19-03-15 18:04:14 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3#033[0m
Mar 15 14:04:21 ron dockerd[1071]: time="2019-03-15T14:04:21.525806095-04:00" level=info msg="Container f8377c8e5d9cc4b79ba795a6bb06dc88644f3cc8cd4d07ddb5519958b153bdc4 failed to exit within 10 seconds of signal 15 - using the force"
Mar 15 14:04:21 ron hassio-supervisor[1826]: #033[31m19-03-15 18:04:21 ERROR (MainThread) [aiohttp.server] Error handling request#033[0m
Mar 15 14:04:21 ron hassio-supervisor[1826]: Traceback (most recent call last):
Mar 15 14:04:21 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
Mar 15 14:04:21 ron hassio-supervisor[1826]:     resp = await task
Mar 15 14:04:21 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
Mar 15 14:04:21 ron hassio-supervisor[1826]:     resp = await handler(request)
Mar 15 14:04:21 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
Mar 15 14:04:21 ron hassio-supervisor[1826]:     return await handler(request)
Mar 15 14:04:21 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/hassio/api/security.py", line 99, in token_validation
Mar 15 14:04:21 ron hassio-supervisor[1826]:   File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 200, in websocket
Mar 15 14:04:21 ron hassio-supervisor[1826]:     client = await self._websocket_client()
I don’t have any help, but my instance of HASSIO has been restarting randomly over the past few days.
Mine too…The log doesn’t help me other than saying
Tue Apr 02 2019 23:02:27 GMT+0100 (British Summer Time)
Ended unfinished session (id=13 from 2019-03-30 09:19:07.137903)
Anyone knows anything about this. I am seeing this too and it;s quite annoying…
Hi all,
I have restarts each hour like if it is scheduled.
I wouldn’t care about it but it is interrupting my audio and I use same pc as media center.
Any help to prevent those restarts or at least some settings so restarts doesn’t affect my sound.
Thanks a lot
> Dec 28 19:06:14 debian hassio-supervisor[696294]: #033[32m19-12-28 18:06:14 INFO (MainThread) [__main__] Stopping Hass.io#033[0m
> Dec 28 19:06:14 debian hassio-supervisor[696294]: #033[32m19-12-28 18:06:14 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2#033[0m
> Dec 28 19:06:14 debian hassio-supervisor[696294]: #033[32m19-12-28 18:06:14 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding#033[0m
> Dec 28 19:06:14 debian hassio-supervisor[696294]: #033[32m19-12-28 18:06:14 INFO (MainThread) [hassio.core] Hass.io is down#033[0m
> Dec 28 19:06:14 debian hassio-supervisor[696294]: #033[32m19-12-28 18:06:14 INFO (MainThread) [__main__] Close Hass.io#033[0m
