I’m starting with Home Assistant and after some basic tests I installed a clean hass.io on a Ubuntu Docker-CE. After starting I check the logs an so I see that the log of hass.io is UTC und the Home Assistant log himself is on the correct timezone.
So how could I set both to my timezone to have logs with the correct time?
Thanks, Steffen
