Hass.io log wrong timezone
I’m starting with Home Assistant and after some basic tests I installed a clean hass.io on a Ubuntu Docker-CE. After starting I check the logs an so I see that the log of hass.io is UTC und the Home Assistant log himself is on the correct timezone.
So how could I set both to my timezone to have logs with the correct time?
Thanks, Steffen
Sorry, I overlook your answer.
I can see a log under hass.io system, it is called System log and an other ander the Info page. This under hass.io is showing in UTC and I try to see this in my local timezone too.
Regards, Steffen
