Then there are other places stuff is being logged, too. The total size of the /config
folder, including both the log/db mentioned above, is 600mb for me. Yet, the SD card is filled with around 500mb per day (again, please note, this is not the home-assitant.log
nor the database home-assistant_v2.db
, as they are both contained in that folder taking up 600mb in total).
I recently, around 30 days ago, switched to a fresh install on a 256gb SD card. This is the last 30 days of disk usage:
This is a completely managed install. I just installed Home Assistant OS and it manages the entire installation. I have not done any configuration of the OS or Home Assistant. I have only a few standard integrations, and no custom ones.
So I still argue that the Home Assistant OS (not necessarily Home Assistant itself) is not properly configured to be used on an SD card. It will fill it quickly, and it will cause premature wear. The OS is not configurable by adding anything in configuration.yaml.
Also, it is NOT the journal directory, it is capped to around 4 GB worth of logs. Those 4GB only accounts for 1.5% of my SD card. And those capped out in less than a week due to hoem assistant logging a million of these per day (and this, again, is not home-assistant.log nor possible to configure with the logger or recorder, it is more “core” than that and not possible to stop):
[INFO] 127.0.0.1:46963 - 56201 "PTR IN 205.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.017398739s
[INFO] 172.30.32.1:32808 - 56201 "PTR IN 205.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.03401719s
[INFO] 127.0.0.1:46963 - 54793 "PTR IN 206.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.019428702s
[INFO] 172.30.32.1:32808 - 54793 "PTR IN 206.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.056229735s
[INFO] 127.0.0.1:46963 - 44310 "PTR IN 207.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.02200662s
[INFO] 172.30.32.1:32808 - 44310 "PTR IN 207.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.028401523s
[INFO] 127.0.0.1:46963 - 8981 "PTR IN 208.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.017190315s
[INFO] 172.30.32.1:32808 - 8981 "PTR IN 208.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.040225168s
[INFO] 127.0.0.1:46963 - 57744 "PTR IN 209.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.028037081s
[INFO] 172.30.32.1:32808 - 57744 "PTR IN 209.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.034251336s
[INFO] 127.0.0.1:46963 - 55446 "PTR IN 210.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.021985491s
[INFO] 172.30.32.1:32808 - 55446 "PTR IN 210.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.028331542s
[INFO] 127.0.0.1:46963 - 56500 "PTR IN 211.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.028844537s
[INFO] 172.30.32.1:32808 - 56500 "PTR IN 211.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.038552498s
[INFO] 127.0.0.1:46963 - 4628 "PTR IN 212.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.020270934s
[INFO] 172.30.32.1:32808 - 4628 "PTR IN 212.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.030908183s
[INFO] 127.0.0.1:46963 - 61829 "PTR IN 213.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.018694876s
[INFO] 172.30.32.1:32808 - 61829 "PTR IN 213.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.032563574s
[INFO] 127.0.0.1:46963 - 32449 "PTR IN 214.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.019923734s
[INFO] 172.30.32.1:32808 - 32449 "PTR IN 214.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.027972397s
[INFO] 127.0.0.1:46963 - 65129 "PTR IN 215.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.024288173s
[INFO] 172.30.32.1:32808 - 65129 "PTR IN 215.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.032108764s
[INFO] 127.0.0.1:46963 - 37070 "PTR IN 216.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.036590721s
[INFO] 172.30.32.1:32808 - 37070 "PTR IN 216.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.053929924s
[INFO] 127.0.0.1:46963 - 34765 "PTR IN 217.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.02170005s
[INFO] 172.30.32.1:32808 - 34765 "PTR IN 217.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.031686324s
[INFO] 127.0.0.1:46963 - 10327 "PTR IN 218.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.022227767s
[INFO] 172.30.32.1:32808 - 10327 "PTR IN 218.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.043171713s
[INFO] 127.0.0.1:46963 - 34994 "PTR IN 219.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.028921795s
[INFO] 172.30.32.1:32808 - 34994 "PTR IN 219.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.043613246s
[INFO] 127.0.0.1:46963 - 60193 "PTR IN 220.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.017783458s
[INFO] 172.30.32.1:32808 - 60193 "PTR IN 220.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.03398158s
[INFO] 127.0.0.1:46963 - 30011 "PTR IN 221.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.045099417s
[INFO] 172.30.32.1:32808 - 30011 "PTR IN 221.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.059843885s
[INFO] 127.0.0.1:46963 - 34067 "PTR IN 222.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.020059306s
[INFO] 172.30.32.1:32808 - 34067 "PTR IN 222.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.034894792s
[INFO] 127.0.0.1:46963 - 30733 "PTR IN 223.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.017007336s
[INFO] 172.30.32.1:32808 - 30733 "PTR IN 223.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.032401577s
[INFO] 127.0.0.1:46963 - 22448 "PTR IN 224.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.017954586s
[INFO] 172.30.32.1:32808 - 22448 "PTR IN 224.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.032953015s
[INFO] 127.0.0.1:46963 - 53800 "PTR IN 225.0.168.192.in-addr.arpa. udp 55 true 2048" NXDOMAIN qr,rd,ra 44 0.028582076s
[INFO] 172.30.32.1:32808 - 53800 "PTR IN 225.0.168.192.in-addr.arpa. udp 44 false 512" NXDOMAIN qr,rd,ra 44 0.042659144s
and
[45991.087946] IPv6: MLD: clamping QRV from 1 to 2!
[46116.090941] IPv6: MLD: clamping QRV from 1 to 2!
[46241.093935] IPv6: MLD: clamping QRV from 1 to 2!
[46366.097440] IPv6: MLD: clamping QRV from 1 to 2!
[46491.100273] IPv6: MLD: clamping QRV from 1 to 2!
[46616.103397] IPv6: MLD: clamping QRV from 1 to 2!
[46741.107066] IPv6: MLD: clamping QRV from 1 to 2!
[46866.110166] IPv6: MLD: clamping QRV from 1 to 2!
[46991.113832] IPv6: MLD: clamping QRV from 1 to 2!
[47116.117135] IPv6: MLD: clamping QRV from 1 to 2!
[47241.119917] IPv6: MLD: clamping QRV from 1 to 2!
[47366.123420] IPv6: MLD: clamping QRV from 1 to 2!
[47491.125889] IPv6: MLD: clamping QRV from 1 to 2!
[47616.129080] IPv6: MLD: clamping QRV from 1 to 2!
[47741.131697] IPv6: MLD: clamping QRV from 1 to 2!
[47866.135123] IPv6: MLD: clamping QRV from 1 to 2!
[47991.138212] IPv6: MLD: clamping QRV from 1 to 2!
[48116.141547] IPv6: MLD: clamping QRV from 1 to 2!
[48241.144431] IPv6: MLD: clamping QRV from 1 to 2!
[48366.147568] IPv6: MLD: clamping QRV from 1 to 2!
[48491.150588] IPv6: MLD: clamping QRV from 1 to 2!
[48616.153531] IPv6: MLD: clamping QRV from 1 to 2!
[48741.156409] IPv6: MLD: clamping QRV from 1 to 2!
[48866.159156] IPv6: MLD: clamping QRV from 1 to 2!
[48991.162102] IPv6: MLD: clamping QRV from 1 to 2!
[49116.165058] IPv6: MLD: clamping QRV from 1 to 2!
[49241.167972] IPv6: MLD: clamping QRV from 1 to 2!
[49366.170887] IPv6: MLD: clamping QRV from 1 to 2!
[49491.173823] IPv6: MLD: clamping QRV from 1 to 2!
[49616.177548] IPv6: MLD: clamping QRV from 1 to 2!
