Tried that. Gives a Config error. As I understood if you don’t use the Hassio raspberry Image, you will miss this menu? So I wonder How I can easily add some add-ons etc?
not sure here, all of a sudden I got config errors on Hassio (Hassos 0.78.3) without any misconfiguration , and Hassio menu disappeared. Reminiscing of the long struggle I had with Hassio in the pre 66 or so versions. I then learned the hassio: configuration to always show Hassio menu without exception.
So Ive just added it to the configuration.yaml again, just to see if that would indeed cause a config error as you said. It didnt, and it got my Hassio menu back…
