Just started to automate my home few days ago by choosing home assistant as unique solution, and it looks promising so far !
I started with hassbian first, then hass.io cames out, and I decided to switch as I wasnât a very advanced user of home assistant.
I installed few plugins (ssh, samba share, home-bridge) with the ease of a click So far, so good !
Then, few days ago I loggued into the Web UI, and there was no hass.io menu anymore meaning that I canât manage my plugins anymore, eventhough they looks still active (i.e I can log into my RPi using ssh and access configuration.yaml trough the samba share)
Unfortunately updating with hassio homeassistant update and hassio host update to the last version through ssh didnât fix it, and I canât see any error related to this issue in logs.
I tried from both Chrome and Firefox, to reach http://myhomeassistantip:8123/hassio, but I got a 404: Not Found error from both.
Does someone have any clue to solve this issue ? Any tips appreciated !
I was able to install Home Assistant onto my Raspberry Pi 3, but when I launch http://192.168.x.xx:8123, I couldnât see HassIO under the menu tap of Home Assistant. Can someone help me fix this? How do I access the yaml configuration file to enable HassIO to show up? Anybody? Can you please help???!?!?!
It seems if you remove âdiscovery:â from the configuration.yaml that the Hass.io menu link is not shown anymore. Then you need to add âhassio:â to your configuration.yaml.
