Hass.io image, HassOS 2.12
Home Assistant 0.94.4
Pi 3B v1.2 64 bit
Snips.Ai 5.2
Mosquitto broker 4.3
USB headset via direct connection to Pi
mosquitto ignores disabling of port 1883
I disable port 1883 per instructions here:
But in the logs we see it opens it anyway:
[INFO] Setup mosquitto configuration
[WARN] SSL not enabled - No valid certs found!
[INFO] Found local users inside config
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1561128447: mosquitto version 1.5.6 starting
1561128447: Config loaded from /etc/mosquitto.conf.
1561128447: |-- *** auth-plug: startup
1561128447: Opening ipv4 listen socket on port 1883.
1561128447: Opening ipv6 listen socket on port 1883.
1561128447: Opening websockets listen socket on port 1884.
1561128447: Warning: Mosquitto should not be run as root/administrator.
At the moment my only usage for mosquitto is trying to get snip.ai to work.
I also want to disable IPv6 in the app. It’s already disabled in my router.
I tried to follow this some time ago, but my broker stopped working after that so I ended up re-enabling this port.
I was about to open a new issue or asked about it here (don’t remember) but it ended up nowhere.
