i’m running Hassio in docker on dual CPU server (2*E5-2630l v2) and found that performance in some moments (config check. for example) are very low. Checking htop while doing config check i found that only one thread is under heavy load by - which is Hassio.
Is the any solution to push Hassio to use as much cores\threads as possible?
