Hass.io networking changes since 0.58 exposed DNS misconfiguration on hassio host
My hass.io is on supvervisor version 0.58 and hass version 0.51.2:
Both hass and hass.io versions have changed but these are not being seen or reported by hass.io.
Hence I cannot upgrade…
In the logs I am seeing:
17-08-29 11:27:26 INFO (MainThread) [__main__] Start Hassio
17-08-29 11:27:26 INFO (MainThread) [__main__] Run Hassio loop
17-08-29 11:27:26 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/notoriousbdg/hassio-addons repository
17-08-29 11:27:26 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/bestlibre/hassio-addons repository
17-08-29 11:27:26 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/james-fry/hassio-addons repository
17-08-29 11:27:26 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/hassio-addons/repository repository
17-08-29 11:27:26 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/home-assistant/hassio-addons repository
17-08-29 11:27:26 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-08-29 11:27:26 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-29 11:27:31 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-29 11:27:31 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-08-29 11:27:31 INFO (MainThread) [hassio.addons] Startup system run 1 addons
17-08-29 11:27:31 INFO (SyncWorker_7) [hassio.dock.interface] Clean bestlibre/amd64-influxdb docker application
17-08-29 11:27:32 ERROR (MainThread) [hassio.addons.git] Can't pull https://github.com/bestlibre/hassio-addons repo: Cmd('git') failed due to: exit code(1)
  cmdline: git pull -v origin
  stderr: 'fatal: unable to access 'https://github.com/bestlibre/hassio-addons/': Couldn't resolve host 'github.com''.
17-08-29 11:27:32 ERROR (MainThread) [hassio.addons.git] Can't pull https://github.com/notoriousbdg/hassio-addons repo: Cmd('git') failed due to: exit code(1)
  stderr: 'fatal: unable to access 'https://github.com/notoriousbdg/hassio-addons/': Couldn't resolve host 'github.com''.
17-08-29 11:27:32 ERROR (MainThread) [hassio.addons.git] Can't pull https://github.com/james-fry/hassio-addons repo: Cmd('git') failed due to: exit code(1)
  stderr: 'fatal: unable to access 'https://github.com/james-fry/hassio-addons/': Couldn't resolve host 'github.com''.
17-08-29 11:27:32 ERROR (MainThread) [hassio.addons.git] Can't pull https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(1)
  stderr: 'fatal: unable to access 'https://github.com/hassio-addons/repository/': Couldn't resolve host 'github.com''.
17-08-29 11:27:32 ERROR (MainThread) [hassio.addons.git] Can't pull https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(1)
  stderr: 'fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': Couldn't resolve host 'github.com''.
Looks like a problem with DNS in the supervisor container since the version.json on github cannot be retrieved since hosts are not getting resolved…
The OS hosting hass.io (ubuntu) can resolve github.com:
james@hassio:~$ ping github.com
PING github.com (192.30.253.113) 56(84) bytes of data.
64 bytes from lb-192-30-253-113-iad.github.com (192.30.253.113): icmp_seq=1 ttl=                  47 time=79.4 ms
64 bytes from lb-192-30-253-113-iad.github.com (192.30.253.113): icmp_seq=2 ttl=                  47 time=79.5 ms
Any ideas why this can happen @pvizeli?
Actually the problem is wider than just updated.
Since I restarted the hass.io host none of the hass.io docker containers can resolve hostnames.
This means many components stop working:
  • mqtt
  • owntracks
  • darksky weather
  • unifi presence detection with cloud hosted unifi server
From the host OK resolution works fine:
64 bytes from lb-192-30-253-113-iad.github.com (192.30.253.113): icmp_seq=1 ttl=47 time=79.5 ms
64 bytes from lb-192-30-253-113-iad.github.com (192.30.253.113): icmp_seq=2 ttl=47 time=80.0 ms
64 bytes from lb-192-30-253-113-iad.github.com (192.30.253.113): icmp_seq=3 ttl=47 time=79.5 ms
^C
--- github.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 79.544/79.706/80.013/0.217 ms
When I connected to the hass.io supervisor container resolution fails, but you can see that there is connectivity as ping by IP works fine…
bash-4.3# ping github.com
^C
bash-4.3# ping 192.30.253.113
PING 192.30.253.113 (192.30.253.113): 56 data bytes
64 bytes from 192.30.253.113: seq=0 ttl=46 time=79.944 ms
64 bytes from 192.30.253.113: seq=1 ttl=46 time=79.485 ms
^C
--- 192.30.253.113 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 79.485/79.714/79.944 ms
bash-4.3#
So seems definitely is a DNS issue.
@pvizeli could this be related to the networking changes added in 0.58?
No, the hassio container will be run on host dns and it run in both network on same time (hassio-network/docker-network). Only the containers that run on host network will be use the internal dns server from hassio. Other add-ons use the internal docker dns server.
I think you need update the docker, maybe there is a bug? It could be also a local time problem that made that the ssl certs are not valid
Do you see more? On you logs, I can’t see a failing ping. I think there is a time issue.
Thanks for checking further.
Regarding time my docker host is on British Summer Time (GMT+1) and the containers are on UTC (GMT+0)
Taking into account the different TZ the time is the same:
james@hassio:~$ date
Wed 30 Aug 13:52:11 BST 2017
james@hassio:~$ docker exec -i -t hassio_supervisor /bin/bash
bash-4.3# date
Wed Aug 30 12:52:23 UTC 2017
bash-4.3#
I didnt change anything in the host OS or docker install.
Out of interest for the hassio_supervisor container I can see following resolv.conf, which only contains loopback address:
bash-4.3# cat /etc/resolv.conf
search local
nameserver 127.0.0.11
options ndots:0
The homeassistant container has this resolv.conf:
search local
nameserver 172.30.32.2
172.30.32.2 is the IP address of the hassio supervisor…
I hacked the hassio supervisor container resolve.conf (yes I know, naughty :slight_smile: ) to also contain nameserver 8.8.8.8 (google public DNS server) and now hassio supervisor can resolve raw.githubusercontent.com and github.com and hence can get new versions.json and the update is detected + works…
So definitely a DNS issue where the hassio supervisor cannot resolve names.
Question is: how to resolve permanently…
And also why did a perfectly working hass.io install, which I have updated several times, before stop working in this way?
Even with the above “success” for the hassio supervisor, the homeassistant container does not resolve names via hassio supervisor as supposed to:
That is the internal docker DNS Server. Hassio use this server to resolve DNS requests and at the end also all other hassio host add-ons.
If the internal docker DNS server will no work, it mean that some things in your docker Setup is wrong. To fix that permanently you need care that you docker setup work correct with his own internal DNS server. Maybe a docker update on host? I can confirm that with 1.17.03 It work all like it should.
OK will look into this.
Do you know what could have changed to stop this working though?
Its weird that all was good then it stopped working…
I’m going to go with the brutal approach to delete hass.io and reinstall from script.
I’m not sure if this will help you. Since it looks like the docker internal dns server is broken. I think a docker reinstall or update can be have a real affect for you problems. It is true that we first use the internal docker dns approach since 0.58
I have a hunch that 0.58 broke it :slight_smile:
I’m currently doing a full re-install OS (ubuntu mini), Docker and hass.io.
I tried “cleaning” docker of containers, images, network etc then reinstall hassio but it didnt work.
BTW the commands I used to install docker + hassio, and am following again this time, are documented here:
And this time I took a VM snapshot before I installed hassio so no need to reinstall the OS again :slight_smile:
Hi @pvizeli
It’s not good news.
I followed exact same process to install OS, docker and hass.io as with my original install that was working fine up until 0.58 update (see post above linking to the exact commands I ran).
Now hass.io will not install fully:
The script executes, deploys the supervisor and starts the systemd services.
I can access http://hassio:8123/, but it never completes the install.
This is 3-4 hours later now and I am still seeing:
Last time it completed in less than a minute…
Pretty sure its still the docker DNS issue at heart.
Please can you share with me how docker is installed/configured on hassio RPi image?
This is how I install docker on Ubuntu x86:
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
sudo apt-get update
apt-cache policy docker-ce
sudo apt-get install -y docker-ce
Thanks for your input as I currently have zero HASS :open_mouth:
@delstel @mak are you guys still using hass.io on ubuntu? Are you seeing similar issues post 0.58?
I have verified that its the same DNS issue.
The clue is in the 1st error - Couldn’t resolve host ‘github.com’:
ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(128)
      cmdline: git clone --recursive -v https://github.com/home-assistant/hassio-addons /data/addons/core
      stderr: 'Cloning into '/data/addons/core'...
Full logs:
james@hassio:~$ docker logs hassio_supervisor
starting version 3.2.2
17-08-30 16:58:51 INFO (MainThread) [__main__] Initialize Hassio setup
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create Home-Assistant config folder /data/homeassistant
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio ssl folder /data/ssl
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio addon data folder /data/addons/data
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio addon local repository folder /data/addons/local
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio addon git repositories folder /data/addons/git
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio temp folder /data/tmp
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio backup folder /data/backup
17-08-30 16:58:51 INFO (MainThread) [hassio.bootstrap] Create hassio share folder /data/share
17-08-30 16:58:51 INFO (MainThread) [hassio.dock.network] Can't find HassIO network, create new network
17-08-30 16:58:52 INFO (MainThread) [__main__] Run Hassio setup
17-08-30 16:58:52 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/amd64-hassio-supervisor with version 0.60
17-08-30 16:58:58 INFO (MainThread) [hassio.host_control] Send 'info' to HostControl.
17-08-30 16:58:59 INFO (MainThread) [hassio.host_control] Receive from HostControl: { "type": "generic", "version": "0.3", "last_version": "0.3", "hostname": "hassio", "features": ["shutdown", "reboot", "update"], "os": "GNU/Linux" }.
17-08-30 16:58:59 INFO (MainThread) [hassio.homeassistant] No HomeAssistant docker homeassistant/qemux86-64-homeassistant found.
17-08-30 16:58:59 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
17-08-30 16:58:59 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/qemux86-64-homeassistant tag landingpage.
17-08-30 16:59:01 INFO (SyncWorker_2) [hassio.dock.interface] Tag image homeassistant/qemux86-64-homeassistant with version landingpage as latest
17-08-30 16:59:01 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/home-assistant/hassio-addons repository
17-08-30 16:59:07 ERROR (MainThread) [hassio.addons.git] Can't clone https://github.com/home-assistant/hassio-addons repo: Cmd('git') failed due to: exit code(128)
17-08-30 16:59:07 ERROR (MainThread) [hassio.addons] Can't load from repository core
17-08-30 16:59:07 INFO (MainThread) [hassio.addons] Load addons: 0 all - 0 new - 0 remove
17-08-30 16:59:07 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
17-08-30 16:59:07 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
17-08-30 16:59:07 INFO (MainThread) [__main__] Start Hassio
17-08-30 16:59:07 INFO (MainThread) [__main__] Run Hassio loop
17-08-30 16:59:07 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-08-30 16:59:07 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 16:59:12 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 16:59:12 INFO (MainThread) [hassio.tasks] Found new HassIO version None.
17-08-30 16:59:12 INFO (MainThread) [hassio.dock.supervisor] Update supervisor docker to homeassistant/amd64-hassio-supervisor:None
17-08-30 16:59:12 INFO (SyncWorker_3) [hassio.dock.interface] Pull image homeassistant/amd64-hassio-supervisor tag None.
17-08-30 16:59:13 ERROR (SyncWorker_3) [hassio.dock.interface] Can't install homeassistant/amd64-hassio-supervisor:None -> 404 Client Error: Not Found ("manifest for homeassistant/amd64-hassio-supervisor:None not found").
17-08-30 16:59:13 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-08-30 16:59:13 INFO (MainThread) [hassio.addons] Startup system run 0 addons
17-08-30 16:59:13 INFO (MainThread) [hassio.addons] Startup services run 0 addons
17-08-30 16:59:13 INFO (SyncWorker_2) [hassio.dock.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version landingpage
17-08-30 16:59:13 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-08-30 16:59:13 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant
17-08-30 16:59:13 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 17:00:13 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 17:00:18 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 17:00:18 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 17:01:18 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 17:01:23 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 17:01:23 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 17:02:23 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 17:02:28 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 17:02:28 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 17:03:28 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 17:03:33 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 17:03:33 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
Hi - Haven’t used it for a couple of weeks… I’ll check tonight.
yep … my hassio is alive and well :
Supervisor
Version 0.60
Beta channel false
Latest available version 0.60
Host OS
Hostname hassio
Type generic
OS GNU/Linux
Host Control version 0.3
Latest available version 0.3
Home Assistant
Current version 0.52.1
Latest version 0.52.1
2 days of logs :
17-08-29 00:23:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-29 04:39:54 INFO (SyncWorker_3) [hassio.dock.interface] Update docker 0.52 with homeassistant/qemux86-64-homeassistant:0.52.1
17-08-29 04:39:54 INFO (SyncWorker_3) [hassio.dock.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.52.1.
17-08-29 04:41:01 INFO (SyncWorker_3) [hassio.dock.interface] Tag image homeassistant/qemux86-64-homeassistant with version 0.52.1 as latest
17-08-29 04:41:01 INFO (SyncWorker_3) [hassio.dock.interface] Stop homeassistant/qemux86-64-homeassistant docker application
17-08-29 04:41:08 INFO (SyncWorker_3) [hassio.dock.interface] Clean homeassistant/qemux86-64-homeassistant docker application
17-08-29 04:41:09 INFO (SyncWorker_3) [hassio.dock.interface] Cleanup docker images: [‘homeassistant/qemux86-64-homeassistant:0.52’]
17-08-29 04:41:15 INFO (SyncWorker_2) [hassio.dock.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.52.1
17-08-29 04:44:07 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-29 04:44:07 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
17-08-29 04:44:07 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-29 04:44:07 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-29 04:44:08 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-29 04:44:08 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-29 04:44:09 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-29 07:33:03 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-29 07:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-29 07:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-29 07:33:03 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-29 07:33:04 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-29 08:28:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-29 15:33:03 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-29 15:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-29 15:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-29 15:33:03 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-29 15:33:04 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-29 16:33:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-29 19:33:03 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
17-08-29 23:33:03 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-29 23:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-29 23:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-29 23:33:05 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-29 23:33:07 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-30 00:38:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 07:33:03 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-30 07:33:03 INFO (MainThread) [hassio.tasks] Addon auto update process 1 tasks
17-08-30 07:33:03 INFO (SyncWorker_2) [hassio.dock.interface] Update docker 0.4.3-p2 with homeassistant/amd64-addon-snips:0.4.9
17-08-30 07:33:03 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/amd64-addon-snips tag 0.4.9.
17-08-30 07:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-30 07:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-30 07:33:03 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-30 07:33:04 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-30 07:36:52 INFO (SyncWorker_2) [hassio.dock.interface] Tag image homeassistant/amd64-addon-snips with version 0.4.9 as latest
17-08-30 07:36:52 INFO (SyncWorker_2) [hassio.dock.interface] Cleanup docker images: [‘homeassistant/amd64-addon-snips:0.4.3-p2’]
17-08-30 08:43:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 15:33:03 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-08-30 15:33:03 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
17-08-30 15:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-08-30 15:33:03 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - danielperna84/hassio-addons: Repository for hass.io add ons repository
17-08-30 15:33:04 INFO (MainThread) [hassio.addons] Load addons: 17 all - 0 new - 0 remove
17-08-30 15:33:08 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “generic”, “version”: “0.3”, “last_version”: “0.3”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”], “os”: “GNU/Linux” }.
17-08-30 16:48:03 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
i also thing that this is a DNS misuse.
please try this : ( to give a clearer image of the network response )
connect to the hassio_supervisor container and start /bin/bash :
sudo docker exec -i -t hassio_supervisor /bin/bash
try :
connection diagnose :
ping google.com
ping github.com
DNS response :
nslookup google.com
nslookup github.com
and try with google dns as the DNS server (8.8.8.8)
nslookup google.com 8.8.8.8
nslookup github.com 8.8.8.8
Usage: nslookup [HOST] [SERVER]
NOTE: type :
exit
to exit the container !!!
Thanks for checking, @mak
You can see the output for some of these in earlier posts as I was diagnosing…
Anyway… here goes:
bash-4.3# ping google.com
ping: bad address 'google.com'
ping: bad address 'github.com'
bash-4.3# nslookup google.com
nslookup: can't resolve '(null)': Name does not resolve
nslookup: can't resolve 'google.com': Try again
bash-4.3#
bash-4.3# nslookup github.com
nslookup: can't resolve 'github.com': Try again
bash-4.3# nslookup google.com 8.8.8.8
Server:    8.8.8.8
Address 1: 8.8.8.8
bash-4.3# nslookup github.com 8.8.8.8
Server:    8.8.8.8
Address 1: 8.8.8.8
:frowning:
But if I update /etc/resolv.conf (in the container) the ping and nslookup both immediately work:
search local
nameserver 8.8.8.8
options ndots:0
bash-4.3#
bash-4.3#
Address 1: 192.30.253.112 lb-192-30-253-112-iad.github.com
Address 2: 192.30.253.113 lb-192-30-253-113-iad.github.com
bash-4.3#
bash-4.3#
PING github.com (192.30.253.113): 56 data bytes
64 bytes from 192.30.253.113: seq=0 ttl=46 time=579.916 ms
64 bytes from 192.30.253.113: seq=1 ttl=46 time=80.160 ms
64 bytes from 192.30.253.113: seq=2 ttl=46 time=84.541 ms
64 bytes from 192.30.253.113: seq=3 ttl=46 time=79.929 ms
^C
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 79.929/206.136/579.916 ms
Also now HASS kicked into life on the 60 sec retries since github.com now can be resolved:
17-08-30 22:17:45 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 22:18:45 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 22:18:50 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json -> [Errno -3] Cannot connect to host raw.githubusercontent.com:443 ssl:True [Try again]
17-08-30 22:18:50 WARNING (MainThread) [hassio.homeassistant] Error on install HomeAssistant. Retry in 60sec
17-08-30 22:19:50 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-08-30 22:19:50 INFO (SyncWorker_2) [hassio.dock.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.52.1.
17-08-30 22:21:10 INFO (SyncWorker_2) [hassio.dock.interface] Tag image homeassistant/qemux86-64-homeassistant with version 0.52.1 as latest
17-08-30 22:21:10 INFO (MainThread) [hassio.homeassistant] HomeAssistant docker now installed
17-08-30 22:21:10 INFO (SyncWorker_3) [hassio.dock.interface] Cleanup docker images: ['homeassistant/qemux86-64-homeassistant:landingpage']
17-08-30 22:21:15 INFO (SyncWorker_0) [hassio.dock.interface] Stop homeassistant/qemux86-64-homeassistant docker application
17-08-30 22:21:16 INFO (SyncWorker_0) [hassio.dock.interface] Clean homeassistant/qemux86-64-homeassistant docker application
17-08-30 22:21:16 INFO (SyncWorker_0) [hassio.dock.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.52.1
