On boot no ethernet found when i connect a monitor to my Pi (3 Model B+)
I get the following error messages
Net: No ethernet found.
starting USB...
USB0: scanning bus 0 for devices... 4 USB Device(s) found
Hit any key to stop autoboot: 0
... (random startup lines)
Saving Environment to MMC...
The following just loops over and over:
Saving Environment to MMC… Writing to MMC(0)… Warning at drivers/mmc/bcm2835_sdhost.c:408/bcm2835_send_command()!
failed
Failed (1)
I have the same issue, I used 2 SD card and 2 Pi, still the same issue.
I can confirm the SD-card problem. I tried 4 cards with my RasPi 2, only my “Sandisk 32 Ultra (10)” was working. An old Sandisk 32 GB and some meMemory 16GB had the same problems: “No ethernet found”, then stop booting.
I assume you did plug the ethernet cable in?
I did pluged one in. No changes
I am having a similar issue. I plugged in an HDMI monitor to see what was happening at boot and the long story is 1) it won’t boot with the USB Config drive in the RPi 3B+, it doesn’t pick up the WiFi config and when I try again with the network cable connected, it doesn’t pick up the DCHP config for eth0 (which is named based on canonical naming system).
I have the same problem. I try with 2 sd card, sandisk and Kingston 16gb
Exactly the same here
Same issue here, raspberry pi 3B+ works perfect with raspbian and mate, tried 3 different power adapters including the official one. Got a brand new sandisk 32gb class 10 used the recomended 32bit image. Nothing from what i can see it isnt even trying the ethernet… no lights on and yes its plugged in as i say it works fine in raspbian…
Just don’t use hass.io. If you have a working raspbian, just stick with it.
Cant find the hass install for raspian though the instructions on site are not arm compatible. Just the image…that doesnt worj
I have the same issue, I used 2 SD cards and 2 Pi, still the same issue.
also, I do the manual installation and it not working.
