Hass.io Node-Red 1.0 login in but no canvas
I upgraded Node-Red to v1.0 on Hass.io. I even reinstalled completely. On the screen I see I authenticate, but when I open web UI and login I come back to the login screen, no canvas. Although log says I authenticated. Any ideas? No virus scanners on this laptop.
Welcome to Node-RED
31 Oct 14:58:42 - [info] Node-RED version: v0.19.4
31 Oct 14:58:42 - [info] Node.js  version: v8.12.0
31 Oct 14:58:42 - [info] Linux 4.14.78-v7 arm LE
31 Oct 14:58:44 - [info] Loading palette nodes
31 Oct 14:58:52 - [info] Dashboard version 2.9.8 started at /ui
31 Oct 14:58:53 - [info] Settings file  : /etc/node-red/config.js
31 Oct 14:58:53 - [info] Context store  : 'default' [module=memory]
31 Oct 14:58:53 - [info] User directory : /config/node-red/
31 Oct 14:58:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Oct 14:58:53 - [info] Flows file     : /config/node-red/flows.json
31 Oct 14:58:53 - [info] Server now running at http://127.0.0.1:1880/
31 Oct 14:58:53 - [info] Starting flows
31 Oct 14:58:53 - [info] Started flows
31 Oct 14:58:54 - [info] [server:Home Assistant] WebSocket Connected to      http://hassio/homeassistant
31 Oct 14:59:55 - HA Auth - AlainG authenticated
31 Oct 15:00:08 - HA Auth - AlainG authenticated
