My Hassio install lost connection to Trådfri, so did a hardware reboot from Hassio menu. After reboot the Hassio menu is missing.
SAMBA is not working, and SSH are giving me API Error back on “all” commands.
Home Assistant
0.52.1
Home Assistant
0.52.1
I am having the same issue, with the menu except Samba and SSH are still functioning for me. I am also on 0.52.1, any chance anyone has some insights?
Any that may have some suggestions?
SSH still working, but samba and HomeKit is dead…
If i manually try and access http://192.168.1.10:8123/hassio i get a 404
I am having a similar issue. The webpage and SSH are working, but SAMBA isn’t. I just upgraded to version “0.54”. It started saying that my Wemo config was wrong, but I didn’t change anything with it. While I was researching that issue, I lost SAMBA. Thankfully I still have nano with SSH.
config:
wemo:
_ static:
_ _ - [my LAN IP]
Here is the log from the webpage:
2017-09-24 16:53:16 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-09-24 16:53:18 WARNING (MainThread) [homeassistant.setup] Setup of remote is taking over 10 seconds.
2017-09-24 16:53:18 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-09-24 16:53:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component wemo
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 194, in async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self.exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/wemo.py”, line 97, in setup
device = pywemo.discovery.device_from_description(url, None)
File “/usr/lib/python3.6/site-packages/pywemo/discovery.py”, line 39, in device_from_description
uuid = deviceParser.parseString(xml.content).device.UDN
File “/usr/lib/python3.6/site-packages/pywemo/ouimeaux_device/api/xsd/device.py”, line 1582, in parseString
doc = parsexml(BytesIO(inString))
File “/usr/lib/python3.6/site-packages/pywemo/ouimeaux_device/api/xsd/device.py”, line 64, in parsexml
doc = etree.parse(*args, **kwargs)
File “src/lxml/etree.pyx”, line 3441, in lxml.etree.parse
File “src/lxml/parser.pxi”, line 1851, in lxml.etree._parseDocument
File “src/lxml/parser.pxi”, line 1871, in lxml.etree._parseMemoryDocument
File “src/lxml/parser.pxi”, line 1759, in lxml.etree._parseDoc
File “src/lxml/parser.pxi”, line 1125, in lxml.etree._BaseParser._parseDoc
File “src/lxml/parser.pxi”, line 598, in lxml.etree._ParserContext._handleParseResultDoc
File “src/lxml/parser.pxi”, line 709, in lxml.etree._handleParseResult
File “src/lxml/parser.pxi”, line 638, in lxml.etree._raiseParseError
File “”, line 103
lxml.etree.XMLSyntaxError: Premature end of data in tag service line 102, line 103, column 1
2017-09-24 16:53:22 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-09-24 16:53:26 WARNING (MainThread) [homeassistant.components.remote] Setup of platform harmony is taking over 10 seconds.
I re-enabled discovery, but wasn’t able to get into the hass.io panel. I had to run the following command. Once I did, I restarted SAMBA from the panel and everything is working now. Also, I had to re-configure (delete and re-add it) the Wemo Mini Switch in the Wemo app for it to work.
curl -X POST http://IP-HOMEASSISTANT:8123/api/hassio/homeassistant/restart
I have the same issue, but I lost the Hassio menu after I upgraded hassio from HassIO.cli
For me it looks like hassio api is listening to wrong ip address
17-09-29 17:26:46 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
Did you remove discovery:? Add hassio:
Thanks, hassio; helped.
It has been working 2 months without…
