Starting today I’m experiencing all sorts of issues with my Home Assistant. On a restart, I get an invalid config notification for default_config.
Logger: homeassistant.setup
Source: setup.py:215
First occurred: 3:43:25 PM (1 occurrences)
Last logged: 3:43:25 PMSetup of cloud is taking longer than 300 seconds. Startup will proceed without waiting any longer
I have tried multiple server restarts. I also tried removing default_config from the YAML and replaced it with cloud:. No dice.
I checked to see if Casa Nabu was down or if others were reporting the same issue. I didn’t see anything offhand.
I’m running hassio in a ESXI Virtual machine. Just recently I added the wireguard add-on. Beyond that my setup really doesn’t change much. I did update the Core this weekend as well.
Here are my settings:
System Health
version: core-2021.3.2
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.99
arch: x86_64
timezone: America/New_YorkGitHub API: ok
Github API Calls Remaining: 5000
Installed Version: 1.11.3
Stage: running
Available Repositories: 750
Installed Repositories: 16host_os: Home Assistant OS 5.12
update_channel: stable
supervisor_version: supervisor-2021.03.4
docker_version: 19.03.13
disk_total: 97.7 GB
disk_used: 14.2 GB
healthy: true
supported: true
board: ova
supervisor_api: ok
version_api: undefined
installed_addons: TasmoAdmin (0.14.0), Terminal & SSH (9.0.2), Visual Studio Code (3.1.0), Glances (0.11.1), Samba share (9.3.1), Node-RED (8.1.3), Portainer (1.4.0), Mosquitto broker (5.1.1), Home Assistant Google Drive Backup (0.103.1), Duck DNS (1.12.5), WireGuard (0.5.0)dashboards: 1
resources: 4
mode: storage
Any help would be appreciated.
Thanks,
