Trying to install Hass.o on my raspberry pi 3 b+ in order to bring non Homekit devices into my Homekit ecosystem. I’m the complete definition of a newbie when it comes to working with a pi or anything other than Windows or MacOs. I downloaded the image file from the home assistant website (I tried both 32 and 64 bit version of the image). I flash the image onto my SD card with Etcher and then put it in the pi with it connected via ethernet directly into my router.
Once everything gets installed I’m able to access HA running on the pi but the Hassio menu in the sidebar isn’t present. I already tried adding hassio: and discovery: to the configuration.yaml file and that didn’t work. I’m fairly confident that Hassio actually installed because when I look at configuration > info I can see Hassio under integrations and when I look at configuration > users I can see Hassio listed as an administrator.
I’ve flashed and reflashed and reflashed and had no luck. Current version is 0.114.14.
Thanks for any help, I’ve been banging my head against the wall. If you could also explain things to me like I’m 12 that would also be super helpful.
