It has been a while since i updated my hassio… I was afraid to update because it was working fine, and I like better the States view over Lovelace (I am lazy, States worked fine and when I changed to lovelace there where tons of errors) and because I have been busy lately.
Today, after unwillingly updating my IOS app I realized that I needed to update Hassio… but when I hit the Update button, it does nothing. Is it still possible to update from 0.88 to the latest version?
That’s a big jump, so before updating Home Assistant, you should read through the release notes for each major version. Also run the Configuration Check addon before updating to see what needs to be changed in your configuration.yaml. Also make a snapshot and move it to external media before updating.
You also don’t need to jump from 0.88 all the way to 0.102.2. You can go a few versions at a time if needed.
