Hi folks!
Yesterday I set up my Raspberry Pi 2 B+ using Rasbian Stretch. I then installed Hass.IO as described here. Little side note: I had to set the machine type: bash ./hassio_install -m armv7l
The installation process itself worked fine, but the first startup failed. The supervisor wasn’t able to download an additional docker container: [hassio.docker.interface] Pull image homeassistant/armhf-homeassistant tag landingpage.
More information on that issue can be found in this Github closed bug report.
However, I figured a way out to work around that issue. Home Assistant is now up and running.
I’m still puzzled why this issue hasn’t been fixed. Can someone pls. comment on this?
Second, I cannot install a single Add-on. Hass.IO says “This addon is not available on your system.”.
Grepping for armhf
at https://hub.docker.com/u/homeassistant?page=1 reveals several. Hence, these Add-ons are available.
Am I missing something in my setup? Has it something to do with my workaround for the installation process?
Cheers,
Alex
