Tried to install hass.io on Debian (Docker method).
But I can not log-in to it with the standard:
hassio.local:8123 or 192.168.1.217:8123
“Problem loading page”, etc.
The command:
docker ps
Is showing:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
34e159b34131 hassioaddons/node-red-amd64:4.2.1 "/init" About an hour ago Up About an hour addon_a0d7b954_nodered
107fee7c8a17 hassioaddons/home-panel-amd64:1.4.4 "/init" About an hour ago Up About an hour 0.0.0.0:8234->80/tcp addon_a0d7b954_home-panel
70d8f45cf774 hassioaddons/motioneye:0.5.5 "/init" About an hour ago Up About an hour addon_a0d7b954_motioneye
dcf396cfd6d6 homeassistant/amd64-addon-configurator:3.6 "/run.sh" About an hour ago Up About an hour addon_core_configurator
da537310c629 esphome/esphome-hassio-amd64:1.13.6 "/init" About an hour ago Up About an hour addon_15ef4d2f_esphome
e14da6ed7c24 hassioaddons/ssh-amd64:6.3.3 "/init" About an hour ago Up About an hour addon_a0d7b954_ssh
e928b5a4136f hassioaddons/influxdb-amd64:3.3.0 "/init" About an hour ago Up About an hour 0.0.0.0:8086->8086/tcp addon_a0d7b954_influxdb
fb4095100a8b hassioaddons/glances-amd64:0.5.5 "/init" About an hour ago Up About an hour addon_a0d7b954_glances
f5f1af8c9495 homeassistant/amd64-addon-samba:9.0 "/run.sh" About an hour ago Up About an hour addon_core_samba
a4c6fb011818 samccauley/amd64-googlebackup:1.7.1 "/run.sh" About an hour ago Up About an hour 0.0.0.0:8055->8000/tcp addon_3833edd4_googlebackup
a9f0b3875e0d hassioaddons/sonweb-amd64:0.8.2 "/init" About an hour ago Up About an hour 0.0.0.0:9541->9541/tcp addon_a0d7b954_sonweb
39b288638ffe homeassistant/amd64-addon-mariadb:1.3 "/run.sh" About an hour ago Up About an hour 0.0.0.0:3306->3306/tcp addon_core_mariadb
fce88c689938 homeassistant/amd64-addon-mosquitto:5.1 "/run.sh" About an hour ago Up About an hour 0.0.0.0:1883-1884->1883-1884/tcp, 0.0.0.0:8883-8884->8883-8884/tcp addon_core_mosquitto
02cda0351a76 homeassistant/amd64-hassio-dns:1 "coredns -conf /conf…" About an hour ago Up About an hour hassio_dns
673afdf8047a homeassistant/qemux86-64-homeassistant:0.100.2 "/bin/entry.sh pytho…" 4 hours ago Up 45 seconds homeassistant
1177e7c5e397 homeassistant/amd64-hassio-supervisor "/bin/entry.sh pytho…" 6 days ago Up 5 seconds hassio_supervisor
Is that something wrong with this install???
Shoud I do something more to start the ‘hass.io’ ?
I can log to ‘home-panel’, but not to hass.io…
