Is it possible to get bluetooth tracking working with this setup?
I’ve moved from RP3+ to old laptop, everything works except BT tracking.
I see the bluetooth device in ubuntu ->
Yeah, I had it all working on RP3+. I restored my RP3 backup, so config is exactly the same. But for some reason I can’t get it working on this Ubuntu server.
So I’ve read else where that bluetooth doesn’t work on hassio/docker/ubuntu, is this the case? From what I understand, I have to use the RP3 with MQTT to get bluetooth presence working on this setup.
However, I thought others said that it is possible, so I’m very confused on this issue. Starting to think I should have gone for the NUC image
