'Hass.io' on 'proxmox' + 'IntelNUC'... Really good choice
As a another test I installed ‘proxmox’ on new ‘IntelNUC5PPYH’,
Then ‘hass.io’…
I’m really impressed about speed and reaction time, etc.
The only surprise I noticed ‘Configuration check’ option is not appearing.
I did something wrong during install? Or should be enabled somewhere?
I can only ‘restart’ or ‘stop’ the server…
O.K. Solved. It is in ‘advance mode’ of the ‘user’…
Should be running the configuration check command anyway. The UI check misses some problems.
Also, ‘why’ so many ‘quotes’?
O.K. Thx… ‘Yes’, indeed too ‘many’…
Just joking around :wink:
I’ve been looking to move away from my pi 3B+ to some faster hardware…but you just can’t beat the small form factor of the pi (and that it doesn’t need active cooling).
A nuc isn’t that much bigger form factor than a Pi really… totally different experience.
Hmm. Might have to look more into getting one then.
I have a the same setup and was wondering if you are able to restart your home assistant server from Server management in the picture.
When I click restart nothing happens. The only way I can restart is to reboot the Home assistant VM on proxmox.
This is strange… I have no problem to restart from ‘Restart’ button…
Then you probably have an issue in your condiguration, HA won’t let you restart if there is a configuration issue. When you press restart, it always does a condig check
