Supervisor prompted for an update to HASS.IO Core earlier this morning. I updated but Home Assistant did not come back up – I just can’t ping the Pi’s IP address even after letting it be for a few hours.
Since I have an updated snapshot, I decided to reinstall HASS.IO. I downloaded the latest 32-bit image for Pi3B+, used Balena Etcher to write it to the card. However, when I put it back to the Pi, it still won’t boot up.- the red power LED will light up, the ACT led will flash green once then turn off, and then nothing. I waited for 30 minutes and it won’t come up. It doesn’t even grab an IP address from the router.
To see if this is a dead Pi, I flashed the latest NOOBS image to the same SD card, put it in the Pi, and I am able to successfully boot up and even complete installation of RaspOs.
Any ideas?
