3-18 10:41:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File “/usr/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: “Zwave Generic Exception : Can’t find device /dev/ttyACM0 : [‘NoneType: None\n’]”
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/zwave/init.py”, line 275, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File “/usr/lib/python3.6/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [‘Traceback (most recent call last):\n’, ’ File “/usr/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ‘openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t find device /dev/ttyACM0 : [\‘NoneType: None\\\\n\’]”\n’]’
I think it’s telling me it can’t find the z stick
Config info (spaces removed as per suggestion above, actual values ##'d out here for privacy)
zwave:
usb_path: /dev/ttyACM0
network_key: “0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##,0x##”
