This is fantastic! Just started playing with Vagrant and found this is very useful.
Thank you.
Release v1.1.0
Added
- Adds support for USB devices (#19)
- Adds support for audio devices (#18)
- Adds instruction on installing nfsd on Ubuntu (#17)
Fixed
- Fixes RuboCop warnings
Removed
- Removes VMWare support
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Thank you! Really appreciate that!
Thank you so much for this!!! I have never been able to get hass.io working on my Mac Mini in VB with a linux VM. Your install guide worked the first time, now I can rebuild my system. I am done with running on PIs, having to replace SD cards all the time.
What is the update / upgrade process for if/when you release new versions?
Will updating destroy the old container?
Is it even necessary to update?
Thanks again!
Big warning here… this has not been created to run a production system on!
I would recommend a manual Virtualbox with Ubuntu and generic linux Hassio installation if you are aiming for that.
Setup a VirtualBox with an Ubuntu installation, next use these commands to install Hass.io:
https://gist.github.com/frenck/32b4f74919ca6b95b30c66f85976ec58
@frenck. Thanks for the warning. I know I am at risk but I have never been able to get that method working on my Mac Mini. I get ubuntu server installed in the VM, and hass.io, but can never browse to the hass.io via web browser. I used bridge mode when setting up the VM, but it does not work for me.
I am too much a nooby to make it work…
Release v1.2.0
- Removes temporary Docker DNS issue workaround
- Fixes guest IP issue with Vagrant core NFS helper
- Adds option to set default bridge interface (#22) (@dale3h)
- Adds option to keep HA config on destroy (#21) (@dale3h)
- Updated README with configuration options
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck or https://buymeacoff.ee/frenck
I’d like to use an aging 2011 MacBook Air for running hass.io and this Vagrant/VirtualBox setup seems very promising as the basis for a production system. I’ve modified the configuration.yml file to avoid the startup questions and to keep the config files. However, when I install add-ons I don’t see them appear in the addons folder – and that means I have to reinstall them everytime I restart. What am I missing?
Thanks!
Hello, thank you for the VM. It’s a very nice job that allows you to reduce a lot of time. I am trying to share a folder between hassio and windows host but I don’t know how to do it. I would like to store images and movies recorded by motioneye in a folder in windows host system because hassio vm has not enough space and I don’t want to mix data and programs.
Could you explain how to do this?
Regards,
This thing is not for production use and I would strongly advise using it as such.
