In the past few days, I’ve created a VirtualBox/Vagrant virtual machine for running Hass.io, released the source code onto GitHub and sharing it with the community forums as well. I’m wondering if you guys like it, find it useful or maybe got some tips/suggestions on improving it.
About
This Vagrant virtual machine allows you to test and play with Hass.io and Home Assistant, and is a great environment for add-on developers. A simple vagrant up
command would give you a fully installed Hass.io system, in a couple of minutes.
This setup comes preloaded with netdata and Portainer to provide you, even more, insight to what is happing under the hood.
Portainer
Portainer is a lightweight Docker management UI which allows you to easily manage your Docker/Hass.io host.
It allows add-on developers to look at the logs of their add-on, or even get a console into their running add-on to allow for easy debugging issues.
netdata
netdata allow you to monitor your Docker containers (of which Hass.io consists). Simple. Effective. Awesome!
Unparalleled insights, in real-time, of everything happening on your systems, applications, and add-ons with stunning, interactive web dashboards and powerful performance and health alarms.
This gives add-on developers detailed information about the performance and resource usage of their add-ons.
System requirements
This setup does not require a lot. Sure it does cost some CPU & memory, but to be honest, Google Chrome eats more memory these days. This setup is tested on MacOS but should work fine on Linux as well. Windows might work, but is not tested (please let us know!).
When following the installation instructions of the tools in the following chapter, please be sure to check the system requirements of each of those tools.
Getting started
Before launching your Hass.io environment, you must install VirtualBox 5.1 or higher, as well as Vagrant 1.9.0 or higher. These software packages provide easy-to-use visual installers for all popular operating systems and are open source.
Once VirtualBox and Vagrant have been installed, you install hassio-vagrant
by simply cloning this repository. Consider cloning the repository into a folder within your “home” directory.
# Goto your home directory
cd ~
# Clone this repository into a folder called `hassio`
git clone https://github.com/hassio-addons/hassio-vagrant.git hassio
You should check out a tagged version of hassio-vagrant
since the master
branch may not always be stable. You can find the latest stable version on the GitHub Release Page:
# Change the directory to `hassio`
cd hassio
# Checkout the desired release
git checkout v0.1.0
Once you have cloned the hassio-vagrant
repository, you can use the following command to start Hass.io:
vagrant up hassio
After 10 minutes or so, the process would finish and the following messages will appear on your screen:
==> hassio: [INFO] Start services
==> hassio: =====================================================================
==> hassio: Community Hass.io Add-ons: Vagrant
==> hassio:
==> hassio: Hass.io is installed & started! It may take a couple of minutes
==> hassio: before it is actually responding/available.
==> hassio:
==> hassio: Home Assitant is running on the following links:
==> hassio: - http://172.28.128.11:8123
==> hassio: - http://192.168.1.2:8123
==> hassio:
==> hassio: Portainer is running on the following links:
==> hassio: - http://172.28.128.11:9000
==> hassio: - http://192.168.1.2:9000
==> hassio:
==> hassio: Netdata is providing awesome stats on these links:
==> hassio: - http://172.28.128.11:19999
==> hassio: - http://192.168.1.2:19999
==> hassio:
==> hassio: Machine 'hassio' has a post `vagrant up` message. This is a message
==> hassio: from the creator of the Vagrantfile, and not from Vagrant itself:
==> hassio:
==> hassio: Hass.io starting... wait a couple of minutes!
Congratulations! Happy testing/developing
Note: The links and IP addresses are examples, yours may differ and change each time you run this virtual machine
Managing the virtual machine
If you followed the above procedure, you have got Hass.io up and running. But there may be a time where you need to shut it down, start up again or maybe start over again.
Shutting down the virtual machine:
vagrant halt hassio
Starting/Resuming the virtual machine again:
vagrant up hassio
Destroying/Deleting the virtual machine:
vagrant destroy hassio
After you’ve destroyed your Hass.io virtual machine, you can use the start command to create a fresh one.
Note: Please, be aware! Destroying the machine would make you lose your configuration of Home Assistant!
You can also use SSH into the virtual machine, giving you direct access to the Docker host:
vagrant ssh hassio
Shared folders
After starting the Hass.io virtual machine, some folders on your harddrive will be made available. These are shared folders with your Hass.io virtual machine. As files within these folders are changed, they will be kept in sync between your local machine and the Hass.io virtual environment.
The following folders are provided within the location where you have cloned this repository to:
addons
- May contain local add-on (e.g. for development). -
backup
- May contain snapshots made with Hass.io. -
config
- Contains the Home Assistant configuration. -
share
- Cross add-on shared folder. -
ssl
- May contain SSL certificate files.
Note: When destroying the Hass.io virtual machine, the contents of the config
folder WILL BE DELETED. All other folders are left untouched.
Contributing
This is an active open-source project. We are always open to people who want to use the code or contribute to it. We’ve set up a separate document for our contribution guidelines.
Thank you for being involved!
We are also looking for maintainers!
Please send Franck Nijhof a message when you are interested in becoming one.
Support
You can always get support here at the Home Assistant community forums, join the conversation!
You have several options to get them answered:
- The Home Assistant Discord Chat Server for general Home Assistant discussions and questions.
- Join the Reddit subreddit in /r/homeassistant
- Open an issue on GitHub
We will do our best to help you out!
