Running home assistant off the Raspbian and all in one installer. As it seems no longer supported and the python 3.4 will be ruled out soon want to decide which way to go.
So the first possible way would be raspbian + manual install of the HA. Doesn’t seem a hard way to go and i will keep other software as well.
Second is installing HassIO but have no idea on the Resin OS. Seems more like ESXi with VMs (Docker images). SO what is the HA image based on?
Will i be able to set up bluetooth pulse audio support for a BT speaker?
Will i be able to access RPi3 pins to run mysensors gateway software https://www.mysensors.org/build/raspberry
Put somesoftware and run shell commands like
sound_intruder: for i in {1..5} ; do /usr/bin/aplay /home/homeassistant/.homeassistant/sounds/files/alarm_hard.wav ; done
or
onkyo_dynvol: '/srv/homeassistant/homeassistant_venv/bin/onkyo -n709 audyssey-dynamic-volume={{states.input_select.onkyo_dynvol.state}}'
or
command_off: 'python3 /home/homeassistant/.homeassistant/shell/orvibo/orvibo.py -m addc233658f6 -x irda -e /home/homeassistant/.homeassistant/shell/orvibo/cmds/TOSHIBA-AC-OFF.ir'
Still be able to acess USB and use it for modbus (have a chinese usb modbus converter us 001 Device 006: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter)
