For info, issue: Hass.io provides no error messages shown when starting add-ons, which fail when attempting to start.
My Home Assistant is in the form of Hass.IO in Docker on a virtualized Ubuntu Server 18.04, as per these instructions.
As an example, I already have an server running on the same port as the add-in wants to bind to, im my case APC UPS Daemon is running on the Ubuntu server and so when trying to start the Hass.io apcupsd add-on it fails and the only line in the logs is: “Error grabbing logs: EOF”.
The issue turned out to be I already had a APCUPSD server running on the same machine, so the new docker container could not start because port was in use (error message: 3551: bind: address already in use).
Only found by using Docker Portainer by manually starting the apcupsd Hass.io add-on, as the hassio interface does not give error messages!
Logged as an issue: https://github.com/home-assistant/hassio/issues/689
