Hass.io PS4 component?
Does anyone know how to get hass.io to connect to mp ps4 and control it? i found this: https://github.com/hmn/home-assistant-config/wiki/media_player_ps4. But im not sure if it will work on Hass.io? If it does can someone tell me how to install/setup? It needs ps4 waker and nodeJS apparently…
Gershy13
Interested to know same
I still haven’t found a way…
did you manage to get it working?
No pal sorry. Started from scratch and went back to all in one installer.
did you get it working on there? I managed to get the credentials on my pi, and installed the hassio add on, and it seems to be working except it doesnt detect the ps4. its stuck on where it says listening on 0.0.0.0:3031
Yep I got it working… but disabled it a little bit after to try diagnose some errors by scaling back components.
I did note when it was set initially I had to be logged out of the app on the phone to work… seemed to block the pi from access it. Also needed to use sudo in my command on/off. On way home now to set back up so will see if there was anything else
thanks…it was sorta working installed normally on the pi, but it didnt work in home assistant…
