HI,
I am using a raspberry 4 with hass.io and want to get bash script running.
The idea is from: https://community.home-assistant.io/t/integration-schellenberg/102832/50?u=cubertt
My Problem is:
I have a command that works via ssh plugin but not via bash:
echo “ss119020000” > /dev/ttyACM1
bash file:
echo “init” > /dev/ttyACM0
sleep 1
echo “ss119020000” > /dev/ttyACM0
sleep 1
I want to start the bash script via an automation or a script within homeassistant.
If i try to start the bash script via ssh i get:
Readonly file systeme 1: /dev/ttyACM0
'leep invalid number 1`
Readonly file systeme 3: /dev/ttyACM0
Any help would be appriciated
