I’m using Hass.io (HassOS) on a RPI 3 B+ and I need to run a shell command on startup, more specifically I need to run modprobe snd-dummy
to create a dummy audio device for a fork of google assistant sdk.
I’m having difficulty finding any way to run this command on startup though, as the rc.local
is read-only, I’m not allowed to create any new services, and trying to run the command with HA’s shell_command
fails, I also tried running the command through SSH with a shell_command
but I get the error:
modprobe: FATAL: Module snd-dummy not found in directory /lib/modules/4.19.126-v7
because the docker container lacks access to /lib/modules
Does anyone have any idea of how I could achieve this?
Edit: This command requires root, and it works if I write it manually with a wifi keyboard outside of docker.
