Hass.io Smartthings
I have been working on this for some time and referring the forums but am still unsuccessful. I am noob.
I installed Hassio onto my raspberry pi 2. It was successful.
I installed configurator
I installed mosquito and added the mqtt to the config file with the IP address.
I install stjohnson smartthings bridge
I copied the code and created the app and devices in smartthings
I ran the app in smartthings on android
I get “starting version 3.2.2
info: Starting SmartThings MQTT Bridge - v1.3.4
info: Loading configuration
info: Loading previous state
info: Perfoming configuration migration
info: Saving current state
info: Connecting to MQTT at mqtt://192.168.x.xx:1883
info: Configuring autosave
info: Configuring API
info: Listening at localhost:2080
info: Incoming message from SmartThings: smartthings/2Gig CT100 Programmable Thermostat/temperature/state = 71
info: Subscribing to smartthings/Front Door Sensor/acceleration/cmd, smartthings/Contacts/notify/cmd, smartthings/System/notify/cmd
info: Subscribing to smartthings/Front Door Sensor/acceleration/cmd, smartthings/Contacts/notify/cmd, smartthings/System/notify/cmd”
Which seems to me like it connected and should be showing? However, I cannot find any devices within hass.io
Am I missing a step somewhere?
Files I used:
stjohnjohnson/smartthings-mqtt-bridge
/vkorn/hassio-addons
I tried:
Restarting everything
reinstalling everything
Using the mac address of the ifconfig eth0
I believe you need to add the MQTT Sensors to your configuration.yaml file
