Hass.io SSH login
H
i have configured a SSH server.
I want use “nmcli” command to set the VLAN. I correctly connet to server and see the Hassio CLI. Now i type “login” command and show this:
core-ssh.local.hass.io login:
where is the user and password?
Tnhanks
Do you found a solution?
I’m stuck on this as well.
The correct Port Is 22222
but what’s the username/password?
i’m currently having the same problem, has anyone here found out anything?
If you are using the SSH & Web Terminal Add-on then you have set your own user/pass. You can’t use “login” from an add-on. But you can use nmcli using the information below:
https://community.home-assistant.io/t/guide-connecting-pi-with-home-assistant-os-to-wifi-or-other-networking-changes/98768
Thank you very much. It’s working fine!
The most important thing is to correctly configure this addon (SSH & Web Terminal), because if you don’t do it in right way, you will have “502 bad gateway” error.
