I have changed over to hass.io using the BRUH Automation video but am annoyed to see that I can’t use sudo commands. I want to use Home Assistant with dasher and this video but I can’t because there are no sudo commands. How can I use these services or is there a way that I can use sudo commands still?
Use dashio, just search and you’ll find it.
Thanks. Do you know about 433mhz plugs?
I use a load of them and did try to set them up following that guide before hassio but had no luck. May have been the receiver/transmitter I had was faulty but I just gave up, got an RM pro and haven’t looked back.
There is no sudo because you already are root so no sudo needed
