I recently moved to a Hass.io based installation on a Raspberry Pi 3B+ and this is mostly is working very smoothly!
One issue I seem to have is that the Hass.io supervisor is not using the timezone from Home Assistant. I saw this pull request so my understanding is that the supervisor should get the timezone from configuration.yaml https://github.com/home-assistant/hassio/pull/69.
I set the correct time_zone
in configuration.yaml however when I check the results of hassio su info
it still returns timezone UTC. As a result, addons like Node-red also use the (incorrect) UTC timezone information.
configuration.yaml
homeassistant:
latitude: !secret home_latitude
longitude: !secret home_longitude
elevation: !secret home_elevation
unit_system: metric
time_zone: Europe/Brussels
hassio su info
"result": "ok",
"data": {
"version": "141",
"last_version": "141",
"channel": "stable",
"arch": "aarch64",
"wait_boot": 5,
"timezone": "UTC",
