carlo@beebox:~$ journalctl -fu hassio-supervisor
-- Logs begin at Wed 2019-09-04 00:03:08 CEST. --
Sep 16 20:30:44 beebox systemd[1]: Starting Hass.io supervisor...
Sep 16 20:30:44 beebox docker[19079]: cannot change profile for the next exec call: No such file or directory
Sep 16 20:30:44 beebox docker[19079]: snap-update-ns failed with code 1: File exists
Sep 16 20:30:44 beebox systemd[1]: Started Hass.io supervisor.
Sep 16 20:30:44 beebox systemd[1]: Stopping Hass.io supervisor...
Sep 16 20:30:45 beebox docker[19141]: cannot change profile for the next exec call: No such file or directory
Sep 16 20:30:45 beebox docker[19141]: snap-update-ns failed with code 1: File exists
Sep 16 20:30:45 beebox systemd[1]: Stopped Hass.io supervisor.
Sep 16 20:30:45 beebox systemd[1]: Dependency failed for Hass.io supervisor.
Sep 16 20:30:45 beebox systemd[1]: hassio-supervisor.service: Job hassio-supervisor.service/start failed with result 'dependency'.
From portainer I’m seeing that also hassioaddons/ssh-amd64:6.3.3 is down
2019-09-16T15:38:42.566245372Z [s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
2019-09-16T15:38:42.726117417Z [s6-init] ensuring user provided files have correct perms...exited 0.,
2019-09-16T15:38:42.731265776Z [fix-attrs.d] applying ownership & permissions fixes...,
2019-09-16T15:38:42.737216810Z [fix-attrs.d] permissions: applying... ,
2019-09-16T15:38:42.872575708Z [fix-attrs.d] permissions: exited 0.,
2019-09-16T15:38:42.873720011Z [fix-attrs.d] done.,
2019-09-16T15:38:42.875735847Z [cont-init.d] executing container initialization scripts...,
2019-09-16T15:38:42.879409188Z [cont-init.d] 00-banner.sh: executing... ,
2019-09-16T15:38:46.025438839Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-16T15:38:46.042610024Z [17:38:46] ERROR: Something went wrong contacting the API,
2019-09-16T15:38:46.046037117Z [cont-init.d] 00-banner.sh: exited 0.,
2019-09-16T15:38:46.049870384Z [cont-init.d] 01-log-level.sh: executing... ,
2019-09-16T15:38:46.259766865Z [cont-init.d] 01-log-level.sh: exited 0.,
2019-09-16T15:38:46.264254859Z [cont-init.d] docker.sh: executing... ,
2019-09-16T15:38:49.096468813Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-16T15:38:49.108254293Z [17:38:49] ERROR: Something went wrong contacting the API,
2019-09-16T15:38:49.262314660Z [cont-init.d] docker.sh: exited 0.,
2019-09-16T15:38:49.267515645Z [cont-init.d] nginx.sh: executing... ,
2019-09-16T15:38:52.170343999Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-16T15:38:52.179771950Z [17:38:52] ERROR: Something went wrong contacting the API,
2019-09-16T15:38:52.331581901Z [cont-init.d] nginx.sh: exited 0.,
2019-09-16T15:38:52.335614338Z [cont-init.d] ssh.sh: executing... ,
2019-09-16T15:38:52.570692016Z [cont-init.d] ssh.sh: exited 0.,
2019-09-16T15:38:52.574822627Z [cont-init.d] user.sh: executing... ,
2019-09-16T15:38:52.652170132Z ln: /root/addons/addons: File exists,
2019-09-16T15:38:52.658871228Z [17:38:52] WARNING: Failed linking common directory: addons,
2019-09-16T15:38:52.662378544Z ln: /root/backup/backup: File exists,
2019-09-16T15:38:52.668255612Z [17:38:52] WARNING: Failed linking common directory: backup,
2019-09-16T15:38:52.671771003Z ln: /root/config/config: File exists,
2019-09-16T15:38:52.677329072Z [17:38:52] WARNING: Failed linking common directory: config,
2019-09-16T15:38:52.680703811Z ln: /root/share/share: File exists,
2019-09-16T15:38:52.686455389Z [17:38:52] WARNING: Failed linking common directory: share,
2019-09-16T15:38:52.688719879Z ln: /root/ssl/ssl: File exists,
2019-09-16T15:38:52.694678605Z [17:38:52] WARNING: Failed linking common directory: ssl,
2019-09-16T15:38:52.708777189Z ln: /root/.ssh/.ssh: File exists,
2019-09-16T15:38:52.712174080Z [cont-init.d] user.sh: exited 1.,
2019-09-16T15:38:52.746652434Z [cont-finish.d] executing container finish scripts...,
2019-09-16T15:38:52.752996290Z [cont-finish.d] 99-message.sh: executing... ,
2019-09-16T15:38:52.817986544Z -----------------------------------------------------------,
2019-09-16T15:38:52.818324581Z Oops! Something went wrong.,
2019-09-16T15:38:52.818597299Z ,
2019-09-16T15:38:52.818894545Z We are so sorry, but something went terribly wrong when,
2019-09-16T15:38:52.819212568Z starting or running this add-on.,
2019-09-16T15:38:52.819516652Z ,
2019-09-16T15:38:52.819847964Z Be sure to check the log above, line by line, for hints.,
2019-09-16T15:38:52.820136608Z -----------------------------------------------------------,
2019-09-16T15:38:52.822829958Z [cont-finish.d] 99-message.sh: exited 0.,
2019-09-16T15:38:52.825005788Z [cont-finish.d] done.,
2019-09-16T15:38:52.826207885Z [s6-finish] waiting for services.,
2019-09-16T15:38:53.047756253Z [s6-finish] sending all processes the TERM signal.,
2019-09-17T16:32:47.531903153Z [s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
2019-09-17T16:32:47.702935762Z [s6-init] ensuring user provided files have correct perms...exited 0.,
2019-09-17T16:32:47.708716982Z [fix-attrs.d] applying ownership & permissions fixes...,
2019-09-17T16:32:47.717579442Z [fix-attrs.d] permissions: applying... ,
2019-09-17T16:32:47.902165959Z [fix-attrs.d] permissions: exited 0.,
2019-09-17T16:32:47.904238527Z [fix-attrs.d] done.,
2019-09-17T16:32:47.910164501Z [cont-init.d] executing container initialization scripts...,
2019-09-17T16:32:47.915471586Z [cont-init.d] 00-banner.sh: executing... ,
2019-09-17T16:32:51.082033980Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-17T16:32:51.088407288Z [18:32:51] ERROR: Something went wrong contacting the API,
2019-09-17T16:32:51.094282436Z [cont-init.d] 00-banner.sh: exited 0.,
2019-09-17T16:32:51.098567488Z [cont-init.d] 01-log-level.sh: executing... ,
2019-09-17T16:32:51.313665408Z [cont-init.d] 01-log-level.sh: exited 0.,
2019-09-17T16:32:51.318485059Z [cont-init.d] docker.sh: executing... ,
2019-09-17T16:32:54.149742821Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-17T16:32:54.170937352Z [18:32:54] ERROR: Something went wrong contacting the API,
2019-09-17T16:32:54.305820698Z [cont-init.d] docker.sh: exited 0.,
2019-09-17T16:32:54.308495216Z [cont-init.d] nginx.sh: executing... ,
2019-09-17T16:32:57.222228998Z curl: (7) Failed to connect to hassio port 80: Host is unreachable,
2019-09-17T16:32:57.234962565Z [18:32:57] ERROR: Something went wrong contacting the API,
2019-09-17T16:32:57.373464563Z [cont-init.d] nginx.sh: exited 0.,
2019-09-17T16:32:57.378537557Z [cont-init.d] ssh.sh: executing... ,
2019-09-17T16:32:57.623148739Z [cont-init.d] ssh.sh: exited 0.,
2019-09-17T16:32:57.627993878Z [cont-init.d] user.sh: executing... ,
2019-09-17T16:32:57.709194102Z ln: /root/addons/addons: File exists,
2019-09-17T16:32:57.716337902Z [18:32:57] WARNING: Failed linking common directory: addons,
2019-09-17T16:32:57.720641842Z ln: /root/backup/backup: File exists,
2019-09-17T16:32:57.726145957Z [18:32:57] WARNING: Failed linking common directory: backup,
2019-09-17T16:32:57.729781583Z ln: /root/config/config: File exists,
2019-09-17T16:32:57.735757320Z [18:32:57] WARNING: Failed linking common directory: config,
2019-09-17T16:32:57.738943412Z ln: /root/share/share: File exists,
2019-09-17T16:32:57.745009827Z [18:32:57] WARNING: Failed linking common directory: share,
2019-09-17T16:32:57.747200460Z ln: /root/ssl/ssl: File exists,
2019-09-17T16:32:57.752675700Z [18:32:57] WARNING: Failed linking common directory: ssl,
2019-09-17T16:32:57.767754165Z ln: /root/.ssh/.ssh: File exists,
2019-09-17T16:32:57.770567362Z [cont-init.d] user.sh: exited 1.,
2019-09-17T16:32:57.804929981Z [cont-finish.d] executing container finish scripts...,
2019-09-17T16:32:57.811195637Z [cont-finish.d] 99-message.sh: executing... ,
2019-09-17T16:32:57.876962688Z -----------------------------------------------------------,
2019-09-17T16:32:57.877418936Z Oops! Something went wrong.,
2019-09-17T16:32:57.877788018Z ,
2019-09-17T16:32:57.878170814Z We are so sorry, but something went terribly wrong when,
2019-09-17T16:32:57.878543509Z starting or running this add-on.,
2019-09-17T16:32:57.878909042Z ,
2019-09-17T16:32:57.879288400Z Be sure to check the log above, line by line, for hints.,
2019-09-17T16:32:57.879755072Z -----------------------------------------------------------,
2019-09-17T16:32:57.883691792Z [cont-finish.d] 99-message.sh: exited 0.,
2019-09-17T16:32:57.884421745Z [cont-finish.d] done.,
2019-09-17T16:32:57.886528389Z [s6-finish] waiting for services.,
2019-09-17T16:32:58.107637867Z [s6-finish] sending all processes the TERM signal.,
